what does vtec-e do?
I bought a 94 vx the other day and the valve cover says vtec-e? is that vtec-economy, any help would be appreciated.
1 Post
Re: what does vtec-e do? (civickidd99)
Basically when the vtec-e isnt engaged you are running each cylinder on 1 intake valve wich causes the air to swirl inside the cylinder and when it is engaged it opens both valves the same distance.
please use the SEARCH feature there is a lot of info about this... also check this out:
http://www.leecao.com/honda/vtec/sohcvtece.html
that's a cool site, read up y0!
-Sketch
-Sketch
Re: (Sketch_hs)
what do i search for, vx is too short, vtec-e brings up anything with the word vtec in it, and vtece says there was nothing found?
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civickidd99 »</TD></TR><TR><TD CLASS="quote">what does vtec-e do?</TD></TR></TABLE>
Save gas.
VTEC-E is employed in the following USDM cars:
'92-95 Civic VX
'96+ Civic HX
'01+ Civic EX
'02+ Civic Si
'00+ Insight
'02+ CR-V
'03+ Accord 4-cylinder
'02+ RSX base
Read about how it works at these links:
http://asia.vtec.net/spfeature/vtecimpl/vtec1.html
Save gas.
'92-95 Civic VX
'96+ Civic HX
'01+ Civic EX
'02+ Civic Si
'00+ Insight
'02+ CR-V
'02+ RSX base
Re: what does vtec-e do? (Targa250R)
^^^what he said^^^
vtec-e is not for performance. it helps give better gas mileage. you could work with but motor but imo its not worth changing most of the part on the vtec-e
Re: what does vtec-e do? (O.G triple O.G)
This website will tell you all you need to know about vtec:
DOHC VTEC
SOHC VTEC
SOHC VTEC-E
3 Stage VTEC
VERY good site.
DOHC VTEC
SOHC VTEC
SOHC VTEC-E
3 Stage VTEC
VERY good site.
LSTEG96
04-15-2004 07:48 PM
94civichatchVX
10-30-2003 09:34 PM
