what do you think of my time
first time out on the track 14.5
94 eg si
b16a
jasma header
short ram intake
50 dry
street tire launching at 3000rpm
help me out tell me what i can do to make me go faster
94 eg si
b16a
jasma header
short ram intake
50 dry
Re: what do you think of my time (jdmspec1122)
With the nitrous? hmmm, maybe a little car diet could help if that's your thing. How was your tire pressure? what tires? I ran a 14.82 in my DA (stripped) with a stock B16 and ls header and azenis. good time for the motor, just a little weak with nitrous.
by 50 dry, do you mean it was 50 degreese out and it was dry? or are you runnin a 50 shot? If your not spraying, you have a really good time. If your spraying...um learn how to launch better i guess. What gears did you spray in?
Re: what do you think of my time (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 »</TD></TR><TR><TD CLASS="quote">by 50 dry, do you mean it was 50 degreese out and it was dry? or are you runnin a 50 shot? If your not spraying, you have a really good time. If your spraying...um learn how to launch better i guess. What gears did you spray in?</TD></TR></TABLE>
i mainly sprayed off of the launch i dont know if i was still spinning i just wanted to run the juice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondahans »</TD></TR><TR><TD CLASS="quote">With the nitrous? hmmm, maybe a little car diet could help if that's your thing. How was your tire pressure? what tires? I ran a 14.82 in my DA (stripped) with a stock B16 and ls header and azenis. good time for the motor, just a little weak with nitrous.</TD></TR></TABLE>
what kind of diet can i put it on besides taking out the passenger and rear seats
i dont konw i this will help but i have gsr leather interior
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmspec1122 »</TD></TR><TR><TD CLASS="quote">
i have gsr leather interior</TD></TR></TABLE>
If you want to go fast, you're going to have to say "bye-bye" to the leather. If you want to go real light pull out all the panels, all the carpet, and all the insulation from the inside of the car. But if you want some sort of comfort away from the track just pull the seats. Every little bit helps
Re: what do you think of my time (FrostySol)
what kind of seat should i use for the driver? i dont think i can do the side panels on the doors beacuse i have my speakers in there. i can do the the side panels on the back though. what else can i do? what do you recomend launching at?
Re: what do you think of my time (foz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foz »</TD></TR><TR><TD CLASS="quote">what was your reaction time?</TD></TR></TABLE>
reaction time will not effect 1/4 mile time. you can sit at the starting line for 10 minutes, and still run a 14.5
_____________
im a jackass don't listen to me
For the finest in JDM engines and better pricing than hmotorsonline.com Click Here
[B][I] Can you hear me now? Good!!
2000 EK HB
Modified by Huggy Bear at 2:32 PM 1/29/2004
_____________
2000 EK HB
Re: what do you think of my time (Huggy Bear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear »</TD></TR><TR><TD CLASS="quote">
reaction time will not effect 1/4 mile time. you can sit at the starting line for 10 minutes, and still run a 14.5</TD></TR></TABLE>
true.
true.
spraying in first is not only really bad for your engine, but it also just makes you spin even worse. If you sprayed in first, i would say that you also spun through all of second also. Dont spray till you have traction purdy much. That should lower your times considerably
in the few times that I ran my better times had a better reaction, and my best times had my best reaction time, just a coincidence then?
in the few times that I ran my better times had a better reaction, and my best times had my best reaction time, just a coincidence then?</TD></TR></TABLE>
yes
yes
AHHHHHHHHHH!!!!
MY AVATAR HAS BEEN HIJACKED!!!
oh well i guess copying is the highest form of flatery
Damn Noob
Modified by mist sITR at 3:07 PM 1/29/2004
Damn Noob
Re: what do you think of my time (EpDarks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EpDarks »</TD></TR><TR><TD CLASS="quote">Stealing avatars should result in a BAN. </TD></TR></TABLE>
Yup!
Yup!
400 HP Club
Re: what do you think of my time (C00SI)
well I'm running 13.83 with a b16 in my hatch, bone stock not even a bolt on... so to me a 14.5 with a 50 shot is a really bad time.... IMO
edit: here's something to shoot for with your b16
Modified by THE B at 2:12 PM 1/29/2004
Guest
Posts: n/a
Re: what do you think of my time (mist sITR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mist sITR »</TD></TR><TR><TD CLASS="quote">AHHHHHHHHHH!!!!
Modified by mist sITR at 3:07 PM 1/29/2004</TD></TR></TABLE>
He is ok with it why arent you???
BTW keep at it your times will go down its a hard sport
