What do I need when I swap out my B16 in the EG6??
I have an Eg6 with the B16A2 obd-1 and I just bought a B18C4 (same as your B18C1) it's an OBD2b (I think) I will swap my own injectors, distributor and generator.. that would be all right??
My plan is tyo buy this: Distribuater ring/washerthing Oildrain washer whashers for gearoil?? whashers for fuel lines, MTF gearoil 75W/90, 2.5 L. Castrol 5W/40 oil 4 L.(the one I normally use) washers to the injectors Some coolant fluid and clean water *Clutch fluid (how much and what kind??) Anything else I should think of??? Please help, were dooing this on saturday, so it would be nice to have the right parts ready.. M. Nielsen,,.. Denmark https://honda-tech.com/forums/images/smilies/emwink.gif |
as long as the motor is out of the car, i would also replace the timing belt. i usually use 5w30 oil (which im pretty sure is OEM spec). 5w40 is a bit heavier, usually for european cars (ie BMW). i would only use honda MTF or 10w30 motor oil for the tranny.
that obd2 motor will swap in perfectly with the parts and engine harness from your b16a. i would also get an obd1 p72 GSR ecu to run your new motor |
Re: (dantastic)
Ok.. thanks..
the Timing belt was just changed 100 KM. ago, so no need for that.. About the ECU, that'l wait until winter time, right now I will run it on stock ECU, tuned with Hondata S200.. About the oil maybe my memory is wrong, it might be 5W-30 as the manual says... |
Re: (SOHC_DK.)
def replace the water pump, u dun wanna do all that then it goes out only to take out all your hard work.
