What do I need to run Hondata?
Alright so I have a 1997 del sol si-T and I thought it would be a good idea to use a VAFC as my fuel management but I have now realized that it sucks *** hole. What do I need to run Hondata on my OBD2a ECU? I want to get the S200b, if that helps at all.
Re: What do I need to run Hondata? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">You need to convert to obd1 and get the hondata kit</TD></TR></TABLE>
and get it tuned
and get it tuned
Re: (DELSOLEMITE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DELSOLEMITE »</TD></TR><TR><TD CLASS="quote">
wiring harness adapter, OBDII to OBDI</TD></TR></TABLE>
OBD2A to OBD1 adapter to be more clear.
And an obd1 ecu. P28 would be a good choice.
Where and how much can i get one of these for?
***Edit***
So I need a p28 ecu, an OBD2a to OBD1 conversion harness and the Hondata kit? Im kinda confused as to how this all works. Never ever looked into this stuff before. So I just put the plugs into the the conversion harness and plug the harness into the p28 ecu and wire the Hondata unit? Do I need a chipped P28 or will just a normal p28 work?
***Edit***
Re: (DelSolMike)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMike »</TD></TR><TR><TD CLASS="quote">Where and how much can i get one of these for?
***Edit***
So I need a p28 ecu, an OBD2a to OBD1 conversion harness and the Hondata kit? Im kinda confused as to how this all works. Never ever looked into this stuff before. So I just put the plugs into the the conversion harness and plug the harness into the p28 ecu and wire the Hondata unit? Do I need a chipped P28 or will just a normal p28 work?</TD></TR></TABLE>
http://www.hondata.com/techadapters.html
***Edit***
