what do i need to put a d16y8 in my 94 del sol si
i just got a good deal on d16y8 with 32,000 miles.I'm trying to find out what i need to put it in my 94 si.The engine coming out is d16z6,so do i need a different ecu or what i have searched and i 'm not 100% sure as to what i need thanks
Re: what do i need to put a d16y8 in my 94 del sol si (1SOL2NV)
motor, tranny, ecu..... the remaining components should be the same
oh, wait, you will need to go obd2b -> obd1
Re: what do i need to put a d16y8 in my 94 del sol si (fazt90hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fazt90hatch »</TD></TR><TR><TD CLASS="quote">distributor bolts up different so get a dx distributor and everything else should be plug and play</TD></TR></TABLE>
WTF..... nice 2nd post tho.
Re: what do i need to put a d16y8 in my 94 del sol si (Usdm1)
re-wire dizzy obd1 with the guts from your old si one, keep the p28, eliminate the knock, keep either tranny and you may need the upper driver mount as the bolts may be to narrow a pattern.
the bolt pattern for the dizzy on the z6 IS different then the DX or the Y8. he will have to mod the dizzy holes to use it or just get a OBD1 DX dizzy
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Usdm1 »</TD></TR><TR><TD CLASS="quote">
Wow. He was right but you downed his post. You're cool.
Use obd-1 Dizzy like the guy said. Enjoy the y8!
Noodle$
04-19-2011 10:17 AM
EF9_TryMe
03-03-2008 12:39 AM
rhdekhatchie
01-23-2008 10:04 AM
