What to do?
Re: What to do? (youraquickone)
i would probably be better to have more potential
now what kind of engine swap would be cheap but would deliver great performance(most upgradeable) if i get more money later
Re: What to do? (Loafiedb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loafiedb »</TD></TR><TR><TD CLASS="quote">i would probably be better to have more potential
now what kind of engine swap would be cheap but would deliver great performance(most upgradeable) if i get more money later </TD></TR></TABLE>
b16 or ls
b16 or ls
Multi-paradigm
try a search of the forum if you're looking for companies who will ship motors to you. there's a lot of info. about this kind of thing in the archives.
HMotors (http://www.hmotorsonline.com) is a real good place to start.
Re: What to do? (Screwtape:)
now i have to choose
B16A 88-91 (SiR I) Complete Change Over
B16A 92-93 Integra (XSi) Complete Change Over
B16A 92-95 (SiR-II) Complete Change Over
which would be the best for a 1996 civic lx,and what else do i need with it?
you should try to get an obd2 motor for you obd2 car or atleast an obd1 are you stuck on a b16? do a search if its a complete change over it should come with most of the stuff right? axles shift linkage mounts.
Re: What to do? (e jay one)
Motor
- Cable Tranny (Y1, S1, J1)
- ECU (PR3, PW0)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
- Comes With All Sensors Needed
- LSD Tranny (Optional +$300)
Motor
- Cable Tranny (YS1)
- ECU (PR3)
- Axles with Half Shaft
- Shift Linkage
- Stock Motor Mounts
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Motor
- Hydraulic Tranny (S21, Y21)
- ECU (P30)
- Shift Linkage
- Stock Motor Mounts *
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
How do i know if it is an obd2 motor?
im not stuck on a b16, do you have any other suggestions?
not something too expensive and with a lot of potential
Motor
- ECU (PR3, PW0)
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Motor
- ECU (PR3)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
Motor
- ECU (P30)
- Shift Linkage
- Alternator
- Starter
- Clutch
- Flywheel
- Intake Manifold
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Engine Harness
MayorMcCheese
12-23-2011 07:34 AM
1992HondaCivic
22
07-06-2009 09:04 AM
tinkertime
05-03-2006 03:36 PM
sanjiyan69
01-05-2004 01:37 AM
