what could be a grinding on tranny???
when driving normal i let off the gas and then there is a noise like 2 metel objects grinding. could this be that someone did not put in the right tranny fluid or that there is not enough?
justin
justin
* B A N N E D *
you should have used honda manual transmission fluid or GM syncromesh
you could tell there is enough by removing the fill plug and seeing if you can feel fluid in the hole.
1 Post
Re: (_gurusan_)
You all think that this is a trans related problem? Please people, think before you post. If it was trans related it wouldn't be just when he released the gas pedal.
The sound you hear is common on Hondas, it is very possible that it is a heat shield around the header or cat.
Check to see if either are loose.
that could be the prob? i am going to put the car up tonight. the problem occures also when downshifting. when i put the car up i will check the tranny oil for metal and look if anything is loose.
justin
justin
so is it a rattling noise, with more of a higher frequency or is it like a grinding noise like when you try to slip into 2nd gear instead of 4th at 60mph?
Re: (doggworld1233)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doggworld1233 »</TD></TR><TR><TD CLASS="quote">i think it is more like a grinding noise. i have not tryed to down shift from 4th to 2nd at 60. i will try that and then repost.</TD></TR></TABLE>
omg....Why did you give him this idea...?
Only my VX can do this.
DO NOT ATTEMPT A 4th - 2nd at 60mph!
