WHat computer to run? LS VTEC 97 EX
I have a 97 Civic with LS VTEC , what would be the best way to wire this bad boy up. Probably need new computer, correct>? Due to VTEC Solinoid, oil pressure unit, ? Right now it is running, but it has stock computer with jumper wires, to other computer. IS this crazy, thats how i got it?>
Re: WHat computer to run? LS VTEC 97 EX (xXxIntegra)
if you want to use the jumper harness - p28
if you don't you can use the p2p that came with the car.
I would use the p28
I would use the p28
Re: WHat computer to run? LS VTEC 97 EX (Smith Wise)
use the p28, its easier to chip and **** with, and has less opportunity to get codes for stuff that you **** with, if that makes sense. definately get the p28 chipped to take advantage of the higher revving b series, cause the stock d rev limit is like 7200
