what can i do with my D16Z6
hi im new to cars and would like to know what i can do to modify my 1992 honda civic si . it already has a regular intake , headers and exaust . i want it to be nice and fast but i dont know alot about cars so any opinions would be nice . i want it to have maybe around 170-200 horsepower. thanks
Re: (v192)
NO.... turbo=the cheapest, and prob. the most reliable way to make 170 hp unless you do a swap... the gsr motor swap is going to run you about 3000$ roughly and i could turbo that soch motor for prob. 1500$ so you make the decision... either way. its gonna cost quite a bit to get 170+hp... so do your research... i would just boost 8 psi and do a good tune with a good clutch.. and youll be set
Re: (96teggylsse)
yeah
just like the others... FI (turbo,nitrous, supercharger) are the only real ways to get any gains from such a motor.
I would start saving up, and while you do that... go and explore your options.
you sound like me a few months ago it's almost scary lol.
if you need any advice hit me up on aim (styraphone) or here on HT
and good luck with whatever you start to do!
Re: (v192)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v192 »</TD></TR><TR><TD CLASS="quote">so what about this for now, intake manifold and cam gears ?? what would this do ?</TD></TR></TABLE>
Not much. To get as much hp with low displacement as the motors do stock, they're pretty much tuned as much as they can be from the factory. Some cheaper parts can actually hinder performance. You're only going to get a few hp at best with bolt on parts, and they'll cost quite a bit. Forced induction is the only way to go get close to what you want. You'll spend 3 or 4 times as much with bolt ons and not even get close.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v192 »</TD></TR><TR><TD CLASS="quote">edit* what does I/H/E mean ?</TD></TR></TABLE>
Intake header exhaust
^ im not going to be racing it so i dont wanna put all that money in to it but i just want it to be decent . u know ?
edit * nevermind , i thought i would be looking at around $ 3000 for a turbo kit , but i was looking around and found this
http://titanmotorsports.com/grtukit92cis.html
i could afford this , what do you think ?
Re: (v192)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v192 »</TD></TR><TR><TD CLASS="quote">^ im not going to be racing it so i dont wanna put all that money in to it but i just want it to be decent . u know ?
Doesn't matter what the end use is; to get to what you're describing is talking about a lot of money. You're better off not doing anything, because you'll just be wasting money that you could be saving for a turbo or a swap.
After picking up the IC (which you should get) and whatever misc. things you will need, you'll be pushing over 2K, possibly close to 3K. If you sit back, wait and do some research, you can build a 'junkyard' turbo for 1/2 that price. Kits will always run for a premium.
Originally Posted by v192edit * nevermind , i thought i would be looking at around $ 3000 for a turbo kit , but i was looking around and found this
[url="http://titanmotorsports.com/grtukit92cis.html"
http://titanmotorsports.com/grtukit92cis.html[/url]
Re: (v192)
i dont u should get a greddy kit ( if u live n cali). for ur year car the greddy kit doesnt come with a intercooler or a blow off value. u have to spend money on that if u want more power. *and u have to take out ur after marke header.*
Ek Forever y0!
Re: (vargas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vargas »</TD></TR><TR><TD CLASS="quote">ok does this sound good , ?
cam , pistons, flywheel. and for how much u think i could get all of this including installation</TD></TR></TABLE>
You'll spend twice the amount of money on an n/a build to make a sohc fast.
The ONLY way to make a sohc make 150whp+ and have spent the least money is to turbo it.
If money is an issue. Give up now. It takes money to play. I've been saving for 3 years now and I still drive a stock 2000 civic. It will still be next summer before I'm ready to add suspension and wheels. Much less an engine.
Re: (vargas)
Cams and pistons require more than you think. When you tear into the engine that deep you're going to have to replace other parts along the way. Not to mention ECU tuning.
Re: (stein_k_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stein_k_9 »</TD></TR><TR><TD CLASS="quote">b20 vtech swap ne one? or turbo</TD></TR></TABLE>
Re: (h22ek9forme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v192 »</TD></TR><TR><TD CLASS="quote">hi im new to cars and would like to know what i can do to modify my 1992 honda civic si . it already has a regular intake , headers and exaust . i want it to be nice and fast but i dont know alot about cars so any opinions would be nice . i want it to have maybe around 170-200 horsepower. thanks </TD></TR></TABLE>
You will never pull 170-200hp all motor for any reasonable amount of money. Not only will it cost you more than a turbo or swap, but your car will barely be streetable (idling at 2.5k, very rough idle due to highly aggressive cams creating cam overlay, etc.) - not recommended if you know as much (or little) as you do (actually I don't recommend it at all).
Learn that 125hp means **** - that's 125 brake horsepower (engine horsepower), the horsepower measured at the wheels (in Si units that's Newton Meters (N*m)) converted to HP is around 100-105hp. A 30hp gain would put you around 130-135 at the wheels, not 170.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v192 »</TD></TR><TR><TD CLASS="quote">turbo = too much $
but what could i do to add around 30plus hp .
also how much do carbon fiber hoods go for?</TD></TR></TABLE>
You want 30+ hp with bolt-on crap get a V8, where you can bolt on headers and gain 30hp at the wheels.
The amount of $ it'll take to get your Z6 to have 30hp (which will put it around 130hp at the wheels) will cost more than a cheap, used, turbo kit.
My advice:
Get over the fact that it's slow, swap, or turbo. You won't pull any real power out of it for any reasonable price unless you turbocharge it, in which case you can hit your 170-200whp mark no problem.
My advice:
Just make up your mind... cam,pully and flywheel is not going to do anything.. first of all your head will be stock and if not then it will run you alot more to have someone else put the head together( having a cam and a stock head is pointless, with or without a tune)..... then a pully,**** not so much there and flywheel forget about that not much there either... and why would you fix your motor and not race it? just buy my grand moms car a cadi CTS. you could drive it around and buy grocies and be home in time for murder she wrote. like all the guys are saying just do a swap or turbo or just get NOS(dry kit) at 150 shot but then you will be able to buy a swap after you blow it... .
Eg6_RcR
20
03-30-2004 04:32 PM
