what booster and master cylinder to use for upgrade???
Old 04-19-2003, 07:10 PM
hatchboy93
Guest
Posts: n/a
Default what booster and master cylinder to use for upgrade???
i read on hybrid garage that the guy used a gsr booster and master cylinder. but gsr's have abs.... i cant use that without reflaring my brake lines. what brake booster and master cylinder can i use for my upgrade or rather which car do i get it out of?????
Old 04-19-2003, 07:18 PM
Solbros Owns Me
Evs-One's Avatar
Default Re: what booster and master cylinder to use for upgrade??? (hatchboy93)
do you have 4 wheel disc or rear drums?
Old 04-19-2003, 07:33 PM
hatchboy93
Guest
Posts: n/a
Default Re: what booster and master cylinder to use for upgrade??? (Emerika)
i have the gsr front and rear dics brake setup... i need to upgrade my booster and M/C please help i was thinking i could get the booster and M/C off a 94-95 integra rs or ls that had no abs.... is this right???
Old 04-19-2003, 07:36 PM
Hybrid96EK's Avatar
I don't know if that will work for sure, but I do know you can use the 15/16 cylinder off the 95+ Del Sol Vtec and it will bolt up. The stock CX cylinder is 13/16. I am in the same shoes as you are right now. I don't think I am going to go through all the headaches of replacing the booster, cylinder, and reflaring/bending the lines. The 15/16 one should work just fine from what I have heard from others. Its a direct bolt on as well.
Old 04-19-2003, 07:41 PM
ImprtTuner88's Avatar
Default Re: what booster and master cylinder to use for upgrade??? (Hybrid93Eg)
check out this link, should help you out alot!
https://honda-tech.com/zerothread?id=364783
j3wman
06-27-2012 03:16 PM
roadrunner1
19
02-28-2007 07:44 PM
6spdKEG
09-26-2006 01:45 PM
adrian1281
08-23-2003 09:43 PM
Quick Reply: what booster and master cylinder to use for upgrade???
