what is blockguard..
Unceasing Measure
Re: what is blockguard.. (poormans_typer69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poormans_typer69 »</TD></TR><TR><TD CLASS="quote">someone said does your engine have blockguard but never heard that before...does anyone know</TD></TR></TABLE>
See the red "SEARCH" button in the upper right hand corner of your screen? Go click on that, type in "block guard" hit the "archived posts" button and click "search"
Problem solved.
Problem solved.
Re: what is blockguard.. (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Problem solved.</TD></TR></TABLE>
Good to see you helping as always, Mike .
Because honda blocks have an open deck, so your cylinders are kinda "open" in the space that the coolant flows through.
Block guards keep them straight (in line with the rod journals) so they don't crack at higher RPM under heavy HP. It's like life insurance on your engine that doesn't always work.
Your engine doesn't have a block guard stock...and unless you're really cranking out some #'s I wouldn't recommend one. They're expensive and they don't always work.
TYPE_EG6
12-30-2004 08:56 PM
