what is the best master cylinder , booster and proportioning valve when...
what is the best master cylinder , booster and proportioning valve when doing a JDM ITR 5 lug conversion on an 97 EK . thanks guys for all the help
Re: what is the best master cylinder , booster and proportioning valve when... (SPOONfdEK)
SI/CTR prop, ITR MC/BB
Re: (SPOONfdEK)
Then SI prop and ITR MC/BB
Re: (SPOONfdEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOONfdEK »</TD></TR><TR><TD CLASS="quote">and Oh yeah , but doesnt the ITR have ABS and that master cylinder won't work</TD></TR></TABLE>
It will work.
And dont forget that a JDM 5 lug has 36mm hubs and in the us all civics and integras (including ITR) use 32mm hubs. So you will need JDM axles too or swap the hub end of the axles with Prelude axle ends. Yikes!
It will work.
what year SI , and will there be any extra lines coming out of the ITR master cylinder. or is it a direct bolt on ? and yeah i know about the 36mm axles, im getting them along with my jdm b18c
Re: (SPOONfdEK)
99-00SI prop. The ITR Im told is a direct bolt on for EK's. I used an ABS GSR and had to change one of my flare fittings.
SpeedRacerEX-R
Suspension & Brakes
11-30-2015 06:16 PM
Unjockable
03-09-2003 07:46 PM
EricUSC
20
01-29-2003 07:26 PM
94, civic, conversion, ctr, cylinder, itr, jdm, lug, master, prop, proportional, proportioning, valve
