what is the best d series motor to turbo?
Re: what is the best d series motor to turbo? (92shade)
the d16z6 because the y8 has horrible oil flow characteristics
then the jdm d15b.. the only 1.5L honda motor that I'd boost.
Re: what is the best d series motor to turbo? (ke98248)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ke98248 »</TD></TR><TR><TD CLASS="quote">the d16z6 because the y8 has horrible oil flow characteristics
then the jdm d15b.. the only 1.5L honda motor that I'd boost.</TD></TR></TABLE>
1 Post
in that case ^^^ your best bet is the zc vtec which is the same as the d16z6 so parts will be available for building but also has the low mileage of the jdm d15b.
1 Post
Re: (sr20hardbody)
Guy here in austin swears by the a6 block/z6 head combo with vitaras and eagles and a mildly built head. He had one in a CRX with almost 300hp+ before he blew it on a shitty tune.
Re: (tx_ej8_49)
Originally Posted by JDM_SOHC
hmmm, id still rather go with the D15B and FJT Custom rod/piston combo...
personally i would too but you gotta admit the d15b can be hella confusing when ordering parts. i have one and im still not fully clued in on what parts work on what i just know the vx timing belt works but what tensioners, water pumps etc... and for how long will those custom fjt rods be available?
if your gonna go frankinstein do z6 block with d15b head but hte d15b is a very good motor givin it is only 1.5 if u do a z6/d15b combo try to aim for a d15b tranny also
Seagull Management
Re: (sr20hardbody)
Re: what is the best d series motor to turbo? (_smitty_)
Most would say the d16z6, and all around as a whole I'd agree, I have one sitting at 430whp so they'll hold it. That's fully built, but it's there. If you could piece one, i'd go with a d16a6 shortblock with a z6 head and shimmed oil pump. The a6 girdle is the strogest as it's steel. They're all cheap enough to fix if you wreck one, that's the good thing.
Re: what is the best d series motor to turbo? (Leland)
thanks guys, now what kind of turbo setup should i get when im just trying to have a fast car nothing higher then 300whp.
dont have that much money but want to do it as legit as possible, i dont want to be fixing anything over and over again.
