Wet floor boards in passenger side footwell
Ok I have awet floor board after going through a carwash, it is right under the ecu and soaks the carpet in passenger footwell area? I can hear dripping in that area when I go through the carwash. I want to find the leak, does anybody have any hints or theories that could speed the process along? I dont want a lecture but if you have had the same problem can you let me know where you found the leak.
I know I can spray water all over the front of the car to find it but if there is a common leak spot LMK.
Thanks.
Thanks.
Re: Wet floor boards in passenger side footwell (MotorMouth)
i had a problem when i got my alarm installed. i hooked up some door actuators and forgot to put the plug back on the door jam. where the hinges are. its the little black square rubber boot. water leaked in that spot on my car. hope that helps
92EGMINIME
04-08-2009 12:34 AM
