Were to buy a TCM for JDM B16?
I need a TCM 28100-p2t-0030 for an OBD2a JDM B16 civic auto? Does anyone have a wiring diagram or know were to buy a TCM from?
Seagull Management
Re: Were to buy a TCM for JDM B16?
Hmotorsonline should be able to hook you up, but if you're planning on swapping an automatic B-series into a '96 - '00 civic be aware that its next to impossible to pull off.
I bought the swap from Hmotors. He siad it is out of a JDM 96 civic but says he thinks it doesn't use a TCM but the JDM harness for the Auto trans goes to the shock tower plug which the USDM harness all the trans wires go to the ECU plug so , there has to be a TCM for the JDM trans.
Seagull Management
I don't really know what to tell you, other than I have heard that some JDM B16As actually didn't use a TCM as opposed to all other B-series engines, I thought only the OBD1 versions were like this though. Be aware though that there are numerous wiring issues and for whatever reason a B-series automatic tranny does not clear the frame rail in a USDM '96 - '00 civic (they will in overseas models that came with them, but i'm not sure just exactly what is different about the engine bay that allows them to fit on those models) In any case its far easier to swap in a 5 speed.
Seagull Management
The automatic LS tranny doesn't clear either. 6th gen automatic B-series swap basically doesn't work at all unless you happen to be wiring guru and have mad fabrication skills or feel like paying someone who has those skills some serious cash.
Phantastic
12-01-2021 04:52 PM
Bango_Vang01
08-27-2009 05:14 PM
