Welds in the exhaust
Re: Welds in the exhaust (illicon2003)
as in the number of sections welded together? As long as the inside of the piping isn't covered in crazy puddles from an inexperienced welder, then it should be fine. But the fewer welds the better, less chance of a weld failing, and also it'll look better. Its all about smooth airflow
Re: here's what it looks like (illicon2003)
You mean by refering to the pics?
Weldings on the outside is always a plus, you dont want much welding on the inside of the pipe.
Tig welding is best.
1 Post
those crush bends are hurting you a lot more than any weld bead....but as said above,a good weld shouldn't interfere much on the inside of the joint.
chris
chris
Guest
Posts: n/a
BTW I was told that this exhaust is fine and that exhausts make only 10 whp difference on FI hondas. Another guy told me it sucked ***. Another guy told me that it wasn't too bad and the guy who said it sucked *** was a moron. Thanks
1 Post
Re: (illicon2003)
it's hard to say a specific number.but,mandrel bends and full 2.5" or even 3" would be a lot better than that crush bent stuff you have now.i'd still go with a custom built setup,as it will save quite a bit of money over some Bling-y aftermarket exhaust,but use mandrel bends(JCWhitney sell them),and get a more skilled welder.
chris
chris
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by illicon2003 »</TD></TR><TR><TD CLASS="quote">BTW I was told that this exhaust is fine and that exhausts make only 10 whp difference on FI hondas. Another guy told me it sucked ***. Another guy told me that it wasn't too bad and the guy who said it sucked *** was a moron. Thanks </TD></TR></TABLE>
ONLY 10 WHP?!that's quite a bit of power regardless.if you're talking about a 3" straigh through exhaust compared to a stock exhaust,it will make a lot more power.
is your exhaust better than stock?most definately.
is it better than an exhaust of the same diameter,with all mandrel bends?no
if you can afford a better quality built exhaust,get it.if not,keep what you have over stock.
if somebody uses the term "sucked ***",and is a moron,do you need us to tell you if you should believe him?
chris
chris
thanks</TD></TR></TABLE>
is this your exhuast? if im wrong correct me but are you all sayin that his exhuast is crush bent? i though that was mandrel bent correct me please if im wrong, although im sure the lovely folks on honda-tech, wouldnt let it get by me
1 Post
Re: here's what it looks like (b18c93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c93 »</TD></TR><TR><TD CLASS="quote">
is this your exhuast? if im wrong correct me but are you all sayin that his exhuast is crush bent? i though that was mandrel bent correct me please if im wrong, although im sure the lovely folks on honda-tech, wouldnt let it get by me </TD></TR></TABLE>
yeah-it's cruch bent.look at the bends above and below the LCA.see the change in diameter?
chris
chris
Re: here's what it looks like (TeamNextGenChris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamNextGenChris »</TD></TR><TR><TD CLASS="quote">
chris</TD></TR></TABLE> To me that looks like mandrel bends, crush style would have ripples on the inside of the curve, kinda like fat rolls looking. Mandrel Stretches it as is goes, keeping the same inside diameter, and that is what is appears to be doing. its too smooth for crush. at least a crush done by a common exhaust shop. it could be a cnc bent tube too, which is an intermediate method. Either way, the exhaust is fine and i doubt its worth spending the exessive money for the better exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLeePeR012 »</TD></TR><TR><TD CLASS="quote">You mean by refering to the pics?
Tig welding is best. </TD></TR></TABLE> I couldn't imagine trying to tig weld and entire exhuast, seems like a waste of time. MIG rocks pretty good, it mostly depends on the skill and experience of the operator
1 Post
Re: here's what it looks like (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote"> To me that looks like mandrel bends, crush style would have ripples on the inside of the curve, kinda like fat rolls looking. Mandrel Stretches it as is goes, keeping the same inside diameter, and that is what is appears to be doing. its too smooth for crush. at least a crush done by a common exhaust shop. it could be a cnc bent tube too, which is an intermediate method. Either way, the exhaust is fine and i doubt its worth spending the exessive money for the better exhaust.
that's deifinately NOT mandrel bends.you can easily see on the inner radius of the bend where the piping shrinks in at least .25"-.5"....i've seen muffler shop crush bends that have the ripples,and some that are smooth.i don't know what makes the difference-maybe the wall thickness of the piping or the kind of bender used?
i can take photos of the 2.5" and 3" mandrel bends i have in the garage-they are perfectly round and maintain the exact diameter thorugh the whole 180 degree bend.
chris
chris
you may be right, but in any regards, i don't think he is going to notice a performance advantage at this level.
from what I been told there are 3 methods of bending piping or makin exhuats..
Pressure bend....thats what that is, diameter reduces .25-.5 no ripples
Crush bend......that also reduces but there are ripples or rolls..
Mandrel Bent.....enufff said...
just 2 cents
just 2 cents
