weird whining noise coming from motor?
Old 05-25-2003, 03:38 PM
Nextelbuddy's Avatar
Default weird whining noise coming from motor?
ok i have just put in my b16 1st gen in my 93 hatch and b4 i put it in i put my type r cams in, the type r intake manifold, and a new timing belt. aftyer i dropped the motor in i started it up and let it warm up to temp and put coolant in and everyting is fine but the motor has a whining noise, it sounds like i have a super charger in it and when i rev it up the whining gets faster and louder. i have no check engine light and everything else is fine the oil level is fine just makes a awful whining noise like a super charger. i dont want to drive it so its still in my garage i dont know what it could be i dont want to even drive it to the shop to get it looked at cuz im afraid its gonna break or something. does anyone know what it could be?
Old 05-25-2003, 03:41 PM
gezer's Avatar
Default Re: weird whining noise coming from motor? (nextelbuddy)
maybe one of the belts ?? can u try and locate where it is coming from??
Old 05-25-2003, 03:44 PM
Default Re: weird whining noise coming from motor? (gezer)
i only have a/c belt and altenator belt nd i took the a/c belt off and the altenator belt off and it still makes the noise. i put the altenator belt back on so my battery dont die. but the noise soudns liek its coming from inside the valve cover in teh head somewhere. i think it has something to do with either the type r cams that i had put it or maybe the timing belt and tensioner. if the timing belt is too tight or if the tensioner is bad could that cause the whining noise?
Old 05-25-2003, 03:46 PM
gezer's Avatar
i could see the timing belt making that noise i remember that prob somewhere but i cant remember what it was sorry dude!
Old 05-25-2003, 03:47 PM
gezer's Avatar
What about the timing on the cams, maybe that is causing it. Iam diggin around try to help u man, so sorry if it seems to run into a wall
Old 05-25-2003, 04:09 PM
its kool thanx for tryin to help. i am just baffled at what it is i have never heard this noise b4 ever and it worries me to the point where im losing sleep and pulling hair.
Old 05-25-2003, 04:50 PM
Lord Helmet's Avatar
are you running stock cam gear or adjustable cam gears? adjustable cam gears will make some sound compared to stock cam gear. I had that problem when I switched to adjustable cam gears from stock.
Old 05-25-2003, 05:01 PM
Default Re: weird whining noise coming from motor? (sleeperciv)
i ma running the stock cam gears that came with the type r cams.
crvtkllr
05-04-2007 06:57 PM
hybrid1990crx
09-18-2006 06:25 AM
ludetuner
10-28-2004 05:46 PM
Quick Reply: weird whining noise coming from motor?
