Weird squeeling noise????
In the last 2 weeks I've had this weird squelling noise coming from my car (98 Civic EX w/JDM B16 Stage 5 Clutch) that has gotten progressively worse. At first I thought it was my clutch, but I had just installed that about 10 months ago and it hasn't been in use for 7 out of the 10. Then I thought it could be my CV joint because during my clutch replacement I ended up pulling one of my CV joints apart by accident, but I was able to get it back together (suprising huh?). It's not a constant squeeling it's only when I start to move, and somtimes when shifting into 2nd and when downshifting into 3rd and 2nd. If anyone has any ideas on what it is let me know so I can fix the problem.
Re: Weird squeeling noise???? (UGotsTaBTrippin)
Check the belts. and provide us with more info.
Does it only do it when the car is moving/accelerating. when braking? What about your clutch; name brand or knockoff?
Re: Weird squeeling noise???? (Hex420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hex420 »</TD></TR><TR><TD CLASS="quote">Is your AC on? It could be you compresor.</TD></TR></TABLE>
no i don't have a/c..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LowSlow93Sol »</TD></TR><TR><TD CLASS="quote">Check the belts. and provide us with more info.
Does it only do it when the car is moving/accelerating. when braking? What about your clutch; name brand or knockoff?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UGotsTaBTrippin »</TD></TR><TR><TD CLASS="quote">It's not a constant squeeling it's only when I start to move, and somtimes when shifting into 2nd and when downshifting into 3rd and 2nd. If anyone has any ideas on what it is let me know so I can fix the problem. </TD></TR></TABLE>
it is a stage 5 by compition clutch.
Re: Weird squeeling noise???? (ci_v_ic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ci_v_ic »</TD></TR><TR><TD CLASS="quote">check belts</TD></TR></TABLE>
I only have one belt, my cam belt and it seems to be fine
same here wen i downshift into 2nd. i have ac and either way on or off it still squeels. i have a d16 though. so it mite be a honda thing.
Re: Weird squeeling noise???? (HondaEK9)
squeeling noises are usually your belts. make sure your belts are all tight. mine did this when i did my swap... i tightened the belts down and havent had the embarassing squeel since.
I only have one belt, my cam belt and it seems to be fine</TD></TR></TABLE>
check ur alternator belt!
