weird sound
weird sound
whenever i start my car in the morning, i hear this squeeling sound. its not very loud, but its there. it only does it when the car is idling higher due to cold weather. when i step on my clutch, the squeeling sound goes away. right when i let off the clutch, it comes back. what could it be?
00 civic si
00 civic si
Re: weird sound (dohcdelsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol »</TD></TR><TR><TD CLASS="quote">Might be a belt</TD></TR></TABLE>
but how come it goes away when i step on my clutch?
Re: weird sound (Dj Villain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dj Villain »</TD></TR><TR><TD CLASS="quote">
but how come it goes away when i step on my clutch?</TD></TR></TABLE>
Honestly, i really dont know. But i have people come by my work (gas station) and ask whats that squeeling sound? the answer is always a belt problem.
When my throwout bearing was shot I got more of a grinding noise. I am no mechanic but physically speaking if you depress the clutch then your transmission isn't moving at all. No gears nothing so when that happens you are freeing up alittle of the tension the motor is causing on the belts so maybe that is why it does not squeel when the clutch is pressed ? Just my stupid wild *** guess.
Re: (rxse7n)
I remember on my D16Y8 when the input shaft bearing would whine, but only when moving at low speeds I could hear it, but I doubt that since you said it goes away. Check the accessory belts and get back.
Re: weird sound (Blk2000Si)
On my 2000 EX, I have a squeeling as well. I replaced all the belts, but they needed it; and adjusted them a few months after. It still squeels on cold start up once and a while. I tracked the problem to one of the acc. pulley bearings, I think the A/C, but it's hard to replicate, so I'm not quite sure which one.
CandyMamaRy
01-25-2011 02:38 PM
kihun_cha
12-03-2005 07:24 AM
