weird problem.. cd player 94 hatch
this is 'Sean Eh2' posting on friends name..because im way too lazy to sign out/in
alright so... i have been having problems with cd players ever since i got my car. installed one wrong and it blew up (doh).. then purchased one from KarmaPolice and it didnt work, i didnt know why... recently i purchased one from another friend of mine with the harness already wired up.. i plug it in and.. no go. so im like wtf. so i plug it into blacksheep's integra and it works perfectly.
i was using a borrowed 92 integra tape deck/radio and it works fine (however cannot keep memory settings if the car is turned off for more than 15 min.).
what is wrong with it?
Re: weird problem.. cd player 94 hatch (blacksheep)
sounds like wiring. accessory power and main power wires may be mixed up... i had this issue in a 97 hatch.. sony harness power wires were set up backwards for some reason... worked fine, but memory would disappear when car was turned off... when i switch main pwer and acc wires, it worked fine....
hope this helps
dan
hope this helps
dan
Re: weird problem.. cd player 94 hatch (OpTiX619)
but why would the stock one work but not the alpine? and why would the alpine deck work in another car?
what do i have to change if it is a wiring mix up
to run a stereo you need ground, and accessory power. to keep memory you need main power. so one of these wires may be mixed up for some reason...
