weird noise(suspension)...
so i just installed my AGX/GC this past saturday. installed with my steelies on and just put my good wheels back on...they are only 15's. so i took a long highway ride and heard a few times(4-5) really loud bangs...different size bumps on all occasions. so today i was pulling out of work and it did it again...going over a 1/4 inch curb cut at like 2 mph?!?!? i have pretty much narrowed it down to the driver side rear...this happen to anyone?
Re: weird noise(suspension)... (2000CX)
mine was about 2.5" I raised it up to about 2.0" drop....it happened less, but still happened on really big bumps. the springs are so short, there isn't much you can do. if you jack up your car....and let the wheel hang down...can the spring move freely, or is it tight against the perches?
also recheck all the stupid stuff, like all washers, and bolts are fitted correctly. bumpstops are halved, ect...
H-T Poker champion
Re: weird noise(suspension)... (DragII)
Mine did that because i was missing the castle nut on the passenger side.. might want to check that.. Just a though.
Re: weird noise(suspension)... (Hatchy-Ownzjo0)
The spring is becoming unseated at either the spring base, or tophat.
Then the spring bangs back into place when the car settles.
Raise the car, or find helper, or tender (5lb rate basically) springs to fill the gap.
Or zip tie the spring to the top hat.
Do you have a rear bar?
Re: weird noise(suspension)... (Eee Pee)
no rear bars...would that help? we had forgotten one washer but it was up front driver side...we took it off and put it where it was supposed to be. they are still settling so i might raise it up a bit. also...where can i get helper springs? i see them on full coilover kits all the time.
I had my AGX's installed and it too makes a thumping moise in the rear...at first it was much louder and noticeable, now it seems to have faded away a little but it does seem louder every now and then...
My springs makes a "boing" sound every now and then too! hahaha checked all the hardware and everything seems good. btw, I have H&R OE's
Re: weird noise(suspension)... (GMoney)
well i guess i can just hope mine will fade as well. one thing i did notice on that side...noticably bad camber? i need to get an alignment done anyway...oh well.
did you install the strut correctly? make sure it aint loose under the hood, i know it sounds stupid, but i've seen people make this mistake.
Re: weird noise(suspension)... (Josh02Si)
haven't heard the springs themselves(twanging) making much noise...my last car did that like crazy though. its really the banging thats bothering me. they are all very tight...done with air tools didn't hear it this morning at all but i just want to narrow it down in case i hear it again...it sounds brutal when it does it...like something is definitely getting ruined
Ya mine is just abunch of squeeks and **** its really annoying and its going to be a pain in the *** becuase i am trying to sell the car and when someone is test driving it that doesnt really help the sell factor! haha Which is why i want ot fix this **** hella bad
noises suck right...sometimes when i sit at idle like at a light....my muffler heat shield rattles and i feel like everyone can hear it?!?!?
memo_ej8
04-29-2013 08:51 PM
ekallday13
15
04-23-2009 05:49 PM
