Weird lighting problem
I do not know why this **** keeps happening but here goes
Rear lights work correctly
Front running lights-passenger side stronger then drivers
Low Beams-passenger side brighter/whiter then yellowish drivers side, and for no reason the auxiliary lights are on(dim)
High Beams-Passenger side works properly, drivers side same as low beam
Driver side turn signal doesnt work
Aux Lights dont work
1995 del Sol VTEC with JDM headlights
Re: Weird lighting problem (VTECommie)
replace your bulbs, cheapest solution, if that doesn't work then you get to have fun with wiring grimlens, but for now replace ALL your bulbs. Go to advance auto. I used to work there. Ask for a 10 pack of bulbs, if they don't know what your talking about tell them it's in commercial. Technicaly they are not allowed to sell them to non comercial accounts, so tell them you are picking them up for a friend with a comercial account. Seriously, a 10 pack for commercial is cheaper than a 2 pack retail. But anyways replace all your bulbs, every last one, replace your flashers to. Shouldn't be any more than 20 bucks.
or simply swap your bulbs & see if it's still doing it on the same side with the good working bulbs you already have. You might have to check the wiring. Could have frayed wire or short to power.
CivicSi95
01-28-2012 11:30 PM
GSR936
12-07-2008 01:53 AM
