Weird ilding but when headlights are on it goes away. Help please
Old 10-17-2007, 08:38 PM
HELLAnorcal's Avatar
Default Weird ilding but when headlights are on it goes away. Help please
Just swapped my single cam back into my hatch. Before i swapped out the single cam it ran just fine but now that its swapped back it idles kinda weird. .It idles weird when warmed/not warmed up but it gets worse when its warmed up. It idles near 0k. When i turn the headlights on the weird shaking idle goes away. Any idea what the problem could be ?
Old 10-18-2007, 12:52 PM
Old 10-18-2007, 01:02 PM
philosofy1's Avatar
Default Re: Weird ilding but when headlights are on it goes away. Help please (HELLAnorcal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HELLAnorcal &raquo;</TD></TR><TR><TD CLASS="quote">Just swapped my single cam back into my hatch. Before i swapped out the single cam it ran just fine but now that its swapped back it idles kinda weird. .It idles weird when warmed/not warmed up but it gets worse when its warmed up. It idles near 0k. When i turn the headlights on the weird shaking idle goes away. Any idea what the problem could be ? </TD></TR></TABLE>
replace the pcv valve. when they are clogged they restrict air flow, sometimes causing a low idle.
also, how long was the motor out of the car? maybe doing a tune up will help.
cap/rotor/plugs/wires/air & fuel filters.
Old 10-18-2007, 06:31 PM
1sickEJ's Avatar
check wiring and alternator somtimes a sign its about to go out
Old 10-18-2007, 06:33 PM
WhiteOnRice's Avatar
It's probably idling at 500rpms because 0-500 is not on the tach.
Dyl@n
04-29-2011 08:11 AM
JasonHi
18
04-11-2011 01:12 PM
clutcher
04-06-2005 08:04 PM
CivicNA
08-08-2003 08:40 PM
Quick Reply: Weird ilding but when headlights are on it goes away. Help please
