weird exhaust noise?
when i rev up my car or down shift i get this weird poping noise from my exhaust i cant figure it out people have told me that it is from having a header on my car or i dont have big enough injectors to compensate for more exhaust flow with my header i have bought new spark plug wires and plugs and it still dose the same thing could it be a bad rotor in my dizzy or something like that because every other car that i hear down shift that has a full exhaust dosent pop i wonder if my timing is off?
Re: weird exhaust noise? (RyanG)
make sure all the rubber hangers are tight.all the bolts are tight.and muffler is not hitting against chassis. whats your engine set up? for n/a setup. u dont need big injectors. and bad rotor wont cause your exhaust from poping
Re: weird exhaust noise? (crazyguy)
its from the pressure differences in each runner of the manifold or header. nothing really to worry about really. i personally like the sound. even more so on a V8
Location: everywhere., cali,nevada,new york., united states
Re: weird exhaust noise? (Frickr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Frickr »</TD></TR><TR><TD CLASS="quote">its from the pressure differences in each runner of the manifold or header. nothing really to worry about really. i personally like the sound. even more so on a V8</TD></TR></TABLE>
i like the sound of mine better on my honda!.
Do you still have a cat? If you have a "high flow" cat it's just your lack of back pressure causing a slight vacuum in the exhaust and when you let off the throttle ( while shifting) air is drawn back into your exhaust system causing the *POP*
