Weird A/C light issue
Normally when I left the A/C and recirculating buttons on when turning off the car they would still be on when I came back and turned the car on. They've recently stopped doing this (as if the constant 12v line stopped working.) The stereo also stopped working this week too, but I'm not sure if they're related.
Thanks in advance.
Thanks in advance.
Re: Weird A/C light issue
Bump
I've also noticed that the display lights on the HVAC for everything but the buttons are no longer lit when the headlights are turned on. I assume this is related to my above problem.
Check your interior fuse panel. There should be a radio fuse that also handles interior illumination. That most likely is the backup/memory 12v supply.
I checked the radio fuse on the dashboard fuse panel and it was ok. My constant 12v is only coming in at ~.4v with the ignition off and ~6v with the ignition on. I'm not sure what that means or where the source feeding it comes from.
edit: 7.5 amp under the hood was blown. we'll see if this was the culprit.
SpeedoKing
07-18-2007 06:57 PM
DxBurnoutKing
12-20-2005 04:30 PM
