Weighten stock flywheel
Guest
Posts: n/a
Re: lighten stock flywheel (Mista Bone)
Don't know the stock dx flywheel weighs but its heavy as Nell Carter! I know machining too much material off of it will leave it shatter prone. Mista Boe knows all! Damn Gurus! What are those burn marks on the flywheel though?
D Tranny Guru
Re: lighten stock flywheel (egizzle6)
That is the back side of the flywheel. What you see is the 6 bolt holes and balancing holes.
All you are seeing is clutch dust.......not much compared to what it looked like last weekend when I dropped the tranny!!!!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egizzle6 »</TD></TR><TR><TD CLASS="quote">Don't know the stock dx flywheel weighs but its heavy as Nell Carter! </TD></TR></TABLE>
Im pretty sure its 18lbs.
Re: (m3dia_lab)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by m3dia_lab »</TD></TR><TR><TD CLASS="quote">where do you have them cut at? somewhere they know what they are doing?</TD></TR></TABLE>
Hopefully. I would try your local machine shop.
