Which way should the should the number face on my KYB AGX? Front not rear.
Which way should the should the number face on my KYB AGX? I'm talking about the front under the hood, not the rear. This is for a 2k Civic. I just got my car back from the body shop and i noticed the numbers on the shock were facing different ways. I don't want one front shock on a different setting than the front shock, so does anybody know which way the numbers are suppose to face? And is it higher the number the stiffer? Thanks.
Re: Which way should the should the number face on my KYB AGX? Front not rear. (KPxRyDa)
hey i have those shocks. they are really nice i love them. anyway, if you look where the whole for the screw driver is there is a little dot. where the dot is is where the setting is going to be. the higher the number the harder the setting. i am not sure which way it is supposed to go if you want me to look at mine i will. just as long as the dot is in the same spot you will be fine. and whatever you do, do not lose that screw driver. i lost mine and still havent found one small enough. just a little tip.
oh yeah i have a 99 hatch
[Modified by phatcivic99, 10:20 PM 4/25/2002]
Re: Which way should the should the number face on my KYB AGX? Front not rear. (phatcivic99)
Are you sure that there is a dot? Hmm.. i didn't see one. I'll have to check again.
yeah i am pretty sure. it is on the little whole you really cant see it i didnt see it till i had the same question you did.
for the street, I run 2 in front 3 in back. For autox I used 3 in front and 5 in back. But I will try harder settings next time.
Re: Which way should the should the number face on my KYB AGX? Front not rear. (95CivicSi)
i got 4 in front and 6 rear. man the car handles so well but i recommed 3 in front. i have 4 cause i have a kit and no braces up there. try 8 ones it is soooo hard.
mechanik
09-09-2002 08:23 AM
89civicdx
09-03-2002 05:31 PM
