water pump bad
Re: water pump bad (hbkxtbone)
not really, if your waterpump is bad don't drive around. Replace it along with a timing belt. Take off your AC (how is it bad did the clutch pulley lock or it's not working at all)
"i just found out that my waterpump is bad"
Sorry, you should replace it along with a new timing belt and tensioner pulley.
"what else can go bad?"
Lots of stuff.
"now my a/c doesnt work either. can that be the cause of itnow my a/c doesnt work either. can that be the cause of it?"
A bad water pump has nothing to do with your A/C. The A/C either leaked all the freeon out or your compressor went bad. Only way to know is get it looked at.
Good luck
Lots of stuff.
Good luck
thanks guys..getting the timing belt changed out today with the tension and water pump. as for my ac, this is the 3rd time is messed up on me in on month. gotta have ac living in florida where the sun is almost firing my head off. they fixed the leak in my ac twice already. what else can go bad on it.??
therivler1
01-11-2008 08:07 PM
unhappy_idle
05-22-2006 10:16 AM
