water leaking in a 93 hatch
Old 06-30-2009, 09:37 PM
jdmstyleg's Avatar
Default water leaking in a 93 hatch
ok so heres the deal guys, i have a major leak somewere under my driver side carpeting.
i have taken apart the carpet and looked at the 3 "drain plugs" if you will, i covered them up with silicone hoping that was the cause but it still leakes water.
the carpet is always moist and when it rains it gets soaked.
mind you car has no ac, and it is clearly water thats leaking not coolant
Old 06-30-2009, 09:40 PM
Spike-EG8's Avatar
Default Re: water leaking in a 93 hatch
Well first get those plugs unsealed, so they can do there job. Is your windshield rusted around it, because that will leak water in from there.
Old 06-30-2009, 09:42 PM
jdmstyleg's Avatar
actually yes i have a small rust spot on the top right of my windsheild
right ontop of my drivers side
and wait why unseal them?
Old 07-01-2009, 07:31 AM
jdmstyleg's Avatar
bumppp need help guys
Old 07-01-2009, 08:58 AM
deadazleep's Avatar
not sure how this applies to hondas seeing how mine has never had a problem, but what about the heater core, my roomies went out in his escort and it leaked all over his drivers floor board just the other day
Old 07-01-2009, 10:44 AM
Oh look, I can change this
deschlong's Avatar
The "drain plugs" you are referring to -- not sure where they are exactly -- but they should probably be left open so that the car can "breathe" ... ie., moisture/humidity/condensation can evaporate ... otherwise, this leads to rust. (Leading cause of rust along the rear wheel wells is poor moisture control between the body and the interior panels.)
You don't mention whether you have a sunroof? This is known to lead to carpet moisture, too, when the drain tube has problems. http://civic.indybbs.net/viewtopic.php?f=12&t=2423106
Old 07-02-2009, 08:39 AM
jdmstyleg's Avatar
but if i take the plugs out wouldnt that allow a constant amount of water flowing through the bottom of my car while i drive in the rain?
no no, no sun roof
Old 07-02-2009, 10:02 AM
bob barker's Avatar
i kinda have the same problem but mine leaks in the rear hatch area
Old 07-02-2009, 12:06 PM
jake 92eg d16z6's Avatar
i have a 92 eg hatch about the same as yours water wont go up on my drain wholes leave them unplugged they are there for a reason to drain water next time it rains sit your car and look for where water is running through.
Dekorum
18
09-28-2010 07:55 AM
Civic082382
15
05-20-2009 12:12 AM
StockTeg
06-24-2003 12:27 PM
Kelvin96GSR
11-29-2001 10:48 AM
Quick Reply: water leaking in a 93 hatch
