Trying to replace 96DX coupe Driver Window Regulator. HELP
Old 12-28-2008, 12:47 PM
wade's Avatar
Default Trying to replace 96DX coupe Driver Window Regulator. HELP
Manual window regulator. driver side, 96 DX coupe.
Does the damn steel crank assembly need to be broken/cut off the regulator to get the old unit out and new unit installed/?
Old 12-28-2008, 03:02 PM
Anon51's Avatar
Default Re: Trying to replace 96DX coupe Driver Window Regulator. HELP
no. unbolt window from regulator. and then unbolt regulator. its just a couple 10mm bolts.
Old 01-27-2009, 11:03 AM
slonga's Avatar
I also need help with this, I'm trying to get that crankshaft for the window roller out of the old one because these new ones do not come with it. Beats me, it's ****en stupid. But these things seems to be welded on..can anyone confirm this?
Old 01-27-2009, 11:07 AM
wade's Avatar
jus work with it, it comes out as one piece
Old 01-27-2009, 11:10 AM
slonga's Avatar
I'm trying man it's pissing me off. I even cut the welds off with a dremel and it's not budging. Do I gotta pry it off, cut it off, wiggle it out?
Old 01-27-2009, 11:12 AM
slonga's Avatar
Old 01-27-2009, 11:16 AM
EL Vap133's Avatar
Did you buy an aftermarket regulator and are you sure it is for a manual roll up window?
Old 01-27-2009, 11:17 AM
slonga's Avatar
well the window regulator is from Oriellys, I'm sure it's OEM spec. Everything looks the same I'm just trying to get that dam window shaft off so I can put it on the new one.
Old 01-27-2009, 11:21 AM
slonga's Avatar
here is what I bought:http://www.oreillyauto.com/EW3/Produ...&currentPage=0
Old 01-27-2009, 11:28 AM
zerovandez's Avatar
you don't have to break anything. follow this link guys, http://repo.jackmoves.com/v/erik/album106/album206/
it's for a power window conversion but will explain how to remove the old regulator without damaging anything, it worked for me.
Old 01-27-2009, 11:34 AM
slonga's Avatar
dam it is power windows. I just called Oreillys and asked to confirm, that dumb *** didn't know what I was talking about. Poor customer service, I asked if he can let someone else know or e-mail support to find out. I'm on hold for 10 minutes then he said yes they're power windows then hangs up.
Old 01-27-2009, 01:14 PM
D50boy's Avatar
take it back. you have one for power windows. If you need one for maual, go to the junkyard and get one that is OEM.
Old 01-27-2009, 02:52 PM
wade's Avatar
i got mine from o reillys, same as what you got, it was WRONG and YOURS is WRONG.
they are idiots.
You have to get OEM HONDA and it till have the handle all welded in place and ready to go. its what i had to do.
Old 01-27-2009, 03:10 PM
EL Vap133's Avatar
I thought it looked different. Check your local junkyard/pick-n-pull and you can find them there for cheap. Also check the classifieds and ebay. If that fails try here: www.car-part.com
Old 01-27-2009, 03:24 PM
slonga's Avatar
Thanks, I'm going to return these things tomorrow and get my 70 bux back. Found a local who will let me have the set for 40.
KidRuthless
02-09-2014 05:25 PM
99exT
05-02-2011 06:16 AM
new_climber
10-15-2009 03:51 AM
VEGAN_EG
08-23-2009 07:29 AM
autoxthis
10-30-2008 09:21 PM
Quick Reply: Trying to replace 96DX coupe Driver Window Regulator. HELP
