VX vs HX rims.... need info.. going on 95 ex w 4wheel disc
Whats the difference between vx and hx rims? Whats the weight difference? Ive tried searching but hx and vx are to short and i dont feel like going through 100 pages.
Anyone got pics of vx's?
Ive read some good posts on fitting over disc brakes and needing spacer, i just cant find them anymore.
Im pretty sure im getting vx's and they are going on a 95 civic ex with 4 wheel discs. I have 2 5mm spacers, do i need 2 more...
And how hard are center caps to find>?
thanks
thanks
Risky Business
Re: VX vs HX rims.... need info.. going on 95 ex w 4wheel disc (civiccph22)
Why do you want VX's in the first place? They look small as **** on 4 doors...how do I know? I HAVE THEM. They fit over my LX brakes, but I know they wont fit over the EX ABS brakes without spacers or grinding the caliper down.
VX wheel tech: https://honda-tech.com/zerothread?id=629535
Risky Business
Re: VX vs HX rims.... need info.. going on 95 ex w 4wheel disc (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">I have some VX wheels. They are 13" x 5" wide and 9lbs. I know they will not fit over the ex calipers. so I can't help you there. Heres a pic:
y0 tr0y! Heh your VX wheels ownz me! I don't know if I can come up on tuesday I have a huge physics test but i'll try and get down there at some point.
Re: VX vs HX rims.... need info.. going on 95 ex w 4wheel disc (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Why do you want VX's in the first place? They look small as **** on 4 doors...how do I know? I HAVE THEM. They fit over my LX brakes, but I know they wont fit over the EX ABS brakes without spacers or grinding the caliper down.
Thanks for the link... i dont have a 4 door i have a 2 door...
More links, pics, and info needed
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccph22 »</TD></TR><TR><TD CLASS="quote">
More links, pics, and info needed</TD></TR></TABLE>
What info do you need? Tell me what you're looking for and i'll tell you where it is
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccph22 »</TD></TR><TR><TD CLASS="quote">Im pretty sure im getting vx's and they are going on a 95 civic ex with 4 wheel discs.</TD></TR></TABLE>
VX wheels will not fit. Period. You will need HX wheels.
Risky Business
Re: VX vs HX rims.... need info.. going on 95 ex w 4wheel disc (Targa250R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
VX wheels will not fit. Period. You will need HX wheels.</TD></TR></TABLE>
I thought the inside of VX wheels and HX wheels were the same? That they both cleared the small Civic brakes and could both clear the larger ones with spacers/grinding the calipers down?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch »</TD></TR><TR><TD CLASS="quote">I have some VX wheels. They are 13" x 5" wide and 9lbs. The caps are the same as hx caps. I know they will not fit over the ex calipers so I can't help you there. Heres a pic:
my friend has a 93 si hatch and put some vx wheels which fit about perfect with no problems. is it becuase it doesnt have ABS?
I thought the inside of VX wheels and HX wheels were the same? That they both cleared the small Civic brakes and could both clear the larger ones with spacers/grinding the calipers down?</TD></TR></TABLE>
I think you can only do with the HXs...I'll get a set of VXs to compare them to this weekend and let you know for sure.
Risky Business
Re: VX vs HX rims.... need info.. going on 95 ex w 4wheel disc (RedHackBatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedHackBatch »</TD></TR><TR><TD CLASS="quote">
The 92-93 si hatchbacks have the small front brakes, the same as the 92-00 CX/DX/LX brakes. The VX wheels WILL fit over those. It is the larger front brakes that come on 94-95 Si's and 92-00 EX's that the VX wheels will not clear (according to Targa).
be professional
Yes. '92-93 Si non-ABS hatchbacks have the smaller 9.5" front brakes. All '94-95 Si, and all '92-95 EX have the larger 10.3" front brakes, which the VX wheels will not clear.
HX wheels fit over 10.3" front brakes, but require either slight modification of the caliper brackets, or a spacer.
Risky Business
HX wheels fit over 10.3" front brakes, but require either slight modification of the caliper brackets, or a spacer.</TD></TR></TABLE>
But not VX...?
But not VX...?
be professional
But not VX...?</TD></TR></TABLE>
Maybe with a gigantimous spacer, but I wouldn't recommend it. I could check the clearances tomorrow for sure - I have 1 VX wheel laying around here somewhere.
Just buy bigger wheels and concede the extra weight; VX wheels are just too damn narrow. I'd rather have a 15lb 15x7 than a 9lb 13x5.
Risky Business
Just buy bigger wheels and concede the extra weight; VX wheels are just too damn narrow. </TD></TR></TABLE>
But you can fit 20" tires on them
be professional
But you can fit 20" tires on them </TD></TR></TABLE>
My 235/45-13 21.3"-OD tires on 13x8s are better than your 175/50-13 19.9"-OD tires on 13x5s.
Risky Business
My 235/45-13 21.3"-OD tires on 13x8s are better than your 175/50-13 19.9"-OD tires on 13x5s. </TD></TR></TABLE>
Yeah but were they $39 a piece?
be professional
Yeah but were they $39 a piece? </TD></TR></TABLE>
No.
205/50-15 Kumho 711s were $43 apiece though, so they balance out my tire budget.
No.
so i just bought some rims that wont fit my car.... dammit. Are you guys sure the vx's wont fit even with a 5mm spacer
socal456
33
09-25-2004 11:01 AM
