VX O2 SENSOR
VX O2 SENSOR
I am in need for a o2 sensor for a 92 civic VX with the 1.5 d15z1 vtec-e motor. I have been quoted 373 and up for this sensor new. Is there any one with a cheaper 5 wire o2 sensor or does someone on here have a cheap used one??
Please let me know ASAP. I need this FAST
Modified by EG_GSR_HB at 8:53 AM 7/20/2006
Re: VX O2 SENSOR (EG_GSR_HB)
That O2 sensor is a special kind that has a greater voltage output range than standard O2 sensors on the typical civic. That price is right.
cute little bastard
Yeah the sensors are wideband so they cost a lot more.
Even sparkplugs.com which is usually cheap is selling them for around 440
http://www.sparkplugs.com/more...17960
I should've never thrown mine out...
Re: (EG_GSR_HB)
You might be able to build a circuit that converts from the .1 volt - .9 volt range to the larger range. Search the web and see if someone else has done this.
Re: (dpkelly)
Search the all North American wrecking yards here:
http://www.car-part.com/
And lookup the exhaust manifold for your car. They probably still have the O2 sensor still in it. Good luck.
Re: (dpkelly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpkelly »</TD></TR><TR><TD CLASS="quote">You might be able to build a circuit that converts from the .1 volt - .9 volt range to the larger range. Search the web and see if someone else has done this. </TD></TR></TABLE>
nope, the VX O2 is the NGK L1H1 wideband O2, which as five wires. it's not a simple step up conversion from the normal O2.
you can convert to a standard O2 but you will have to switch to a P28 ECU and chip it with the P07 fuel and ignition maps.
Re: (Relic1)
I have a used stock VX 5 wire O2 sensor I will sell you for $150 shipped. Its confirmed to be working, I had no problems with it when I was using it for my wideband. Let me know.
i have a vx with the same problem. Im using a p28 with the vx motor and vx o2. I have a cel but when i used my 4 wire o2 from my 93 dx motor I still had a cel. soo... can i use the 4 wire o2 and the p28 on the vx engine????? I "think" maybe not cause of the egr crap but i might be wrong.
Re: (StcRacerBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StcRacerBoy »</TD></TR><TR><TD CLASS="quote">i have a vx with the same problem. Im using a p28 with the vx motor and vx o2. I have a cel but when i used my 4 wire o2 from my 93 dx motor I still had a cel. soo... can i use the 4 wire o2 and the p28 on the vx engine????? I "think" maybe not cause of the egr crap but i might be wrong.</TD></TR></TABLE>
You need to right ECU is what you need. Running the P28 WILL continue to throw a code until you rewire the car for the 4 wire. You can't just put one in and expect it to work. Then when you are done, the EGR crap won't work either.
Re: (EG_GSR_HB)
i have my barely used VX o2 sensor in my garage if you want it. 80 dollars shipped and it's yours. still works perfectly. my gas mileage improved by a ton.
bought it brand new from the dealer and used for a couple of months before i went to b-series.
ebay is your friend... item #130009421690
not me but he has two of them for sale... http://motors.search.ebay.com/...yer24
Dude, I have an HX which uses the same o2 sensor. Buy it from Canada. Mine was $250 from an actual Honda Dealership. The dealership is Hamburg Honda, the phone number is (905) 357-2471. Good luck!
Re: (SlowHX)
I actually ordered a p28 and swapping to a 4 wire o2 sesnor. That sucks that I couldnt find the dang ebay auctions for them yesterday or something and ordered a p28 last night
Re: (EG_GSR_HB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG_GSR_HB »</TD></TR><TR><TD CLASS="quote">So how do you wire the VX for a 4 wire??
I saw something about to run a GSR motor but thats not what I want.</TD></TR></TABLE>
I'm not going to teach you how to read a schematic and use a meter. Not trying to be mean, but if you REALLY wanted to rewire it, then you would pick up a manual and get to work.
Re: (vxturbociv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vxturbociv »</TD></TR><TR><TD CLASS="quote">I have a vx with the 4 wire o2 and p28. No cel, it was really simple to rewire it once you figure out the schematics.</TD></TR></TABLE>
That is kinda my point. Although your chipped P28 might also have the O2 disabled as well....
Re: (Hybrid93Eg)
if you disable the o2 wont it run rich or lean. Which ever??
Also vxturbo....Do you know what wires and stuff you changed??
Is it the same as this here
https://honda-tech.com/zerothread?id=1696481
Thanks
Thanks
