The VX hesitating
The VX hesitating
i have a 95 vx. I was just curious what the problem is when you give it some gas it will hesitate for a minute then go? only sometimes, and it's when I floor it. Only in 3rd gear and up though. thanks
Re: The VX hesitating (VXpride)
My old VX motor had that problem. I never did find out what it was though cause I swapped the motor. There, that's your solution. Swap the motor
Seriously though, I changed the plugs, wires, cap, rotor, pcv valve, injectors, and fuel filter. Nothing helped the hesitation. Either a dirty TB or some other sensor I didn't check.
Maybe it has something to do with the lean burn system on the VX models that causes them to act up with age. Clogged close coupled cat? Flakey 5-wire 02's? Carbon build-up in the CC's?
Re: The VX hesitating (nsxmatt)
i've got the same problem. vtec transition happens around approx 2500 rpm. mine seems to only do it in the 2-3k rpm range. i think it is linked to the lean burn issue. thinking the ecu is stumbling into vtec transition.
i've already got a sohc vtec swap sitting in the garage. once i get a header/exhaust system, i think i'm gonna swap them on for a couple of weeks and see if the stumble stops. that will eliminate the cat issue for sure.
The EGR setup is faulty with age, that is a common problem with those types of symtoms. I have a 92 VX and had the same trouble about 3 years ago. Remedy: 99 B18C1 swap, no hesitation now
H-T Poker champion
Re: The VX hesitating (VTECVillain)
Could be the lack of horse power.. or lack of torque.. or all around shittyness of that nasty vx engine.. i was glad to get that **** out of my baby.. .. My tranny sounded like metal on metal.. and thats because it was..
Re: The VX hesitating (Majin-Hatchy-Ownzjo0)
yeah, i'm gonna try a p28 and see how it works. I also have the worst tranny grind ever. Both of my VX's did this bullshit grind and i'm never buyin a stock vx ever again unless it's to do one big *** burnout and blow the engine.
hey, on the topic of VXs, VXs dont have catalytic converters, right?? i'm just curious becuz i got my vx last summer, and i noticed it didnt have one...uhh....hmmmmm......
i still likes my VX tho
thats the thing, a couple of months ago, i got a slip from the gov. saying i need to take an emissions test, but since i'm away at school, the car aint at use, so i sent that little post card saying i need to delay the testing...
but you have a 95 VX, i have a 92..maybe that could be the difference...any 92 vx owners out there??
Re: The VX hesitating (BlackDeuceCoupe)
no..i kinda like the VX for some reason...its like the blacksheep of the civic models of that generation....i like how it has the right options for my tastes...
-no sunroof, alloys, front lip, no power steering, no rear wiper...whatelse...i dont know, thats about it...oh, no side moldings..hehe...and its light too..i'd rather have it than any other model..
Re: The VX hesitating (Heinz57)
isnt the cat on the exhaust manifold? cx and vx had em there and si and dx had them under the car. i may be wrong...
upgraded
08-26-2005 03:52 AM
EGhatched
14
11-19-2003 04:54 PM
