VTEC wont pop (HELP)
i have a 93 civic VX and i did the d15b7 block and a d15z6 head swap. I followed everything that the massive write up said and yet everything works but the VTEC i changed the vtec cilinoid and have the vx wire harness and distributor. What could be the problem???
Re: VTEC wont pop (gsronhatch)
How do you know vtec isn't engaging? If your'e going by a "popping" feeling you are never going to feel it, because you just can't on a stock sohc vtec engine unless you change the engagement point or drop in a higher profile cam. The difference in sound isn't nearly as noticeable as a dohc vtec engine either. The sound is smooth and gradually changes tones, unlike dohc which does so suddenely.
Re: VTEC wont pop (93egSIboi)
Turn your car off and unplug your vtec solenoid.
Bring a hot wire from your battery to the VTEC solenoid plug and see if the solenoid clicks, if it clicks the solenoid is good. SOHC VTEC's dont engage like DOHC VTEC's, duh.
Re: VTEC wont pop (JSPECHB)
hey...I had the same problem...my vtec didnt kick either...a mini is almost like a LSV so u basically need an oil line...did also pop the pin off the block??
Re: VTEC wont pop (DasaEJ1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DasaEJ1 »</TD></TR><TR><TD CLASS="quote">hey...I had the same problem...my vtec didnt kick either...a mini is almost like a LSV so u basically need an oil line...did also pop the pin off the block??</TD></TR></TABLE>
stock vtec engagement on a stock d-series sohc vtec engine is not supposed to "kick" or "pop".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSIboi »</TD></TR><TR><TD CLASS="quote">
stock vtec engagement on a stock d-series sohc vtec engine is not supposed to "kick" or "pop". </TD></TR></TABLE>
It glides into VTEC.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JSPECHB »</TD></TR><TR><TD CLASS="quote">Turn your car off and unplug your vtec solenoid.
Bring a hot wire from your battery to the VTEC solenoid plug and see if the solenoid clicks, if it clicks the solenoid is good. SOHC VTEC's dont engage like DOHC VTEC's, duh. </TD></TR></TABLE>
how would u do that? u have any pics>
do u use a single wire from positive of the battery to the single wire of the vtec solenoid?
Re: VTEC wont pop (Ignitecivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ignitecivic »</TD></TR><TR><TD CLASS="quote">
do u use a single wire from positive of the battery to the single wire of the vtec solenoid? </TD></TR></TABLE>
Why are you asking if you already know how to do it?
Why are you asking if you already know how to do it? </TD></TR></TABLE>
haha thx for the tip , but i havent tried this method before.
It glides into VTEC. </TD></TR></TABLE>
Exactly.
Exactly.
haha yea it definately dont kick or pop
With an intake u can notice it...even non honda heads ask me "was that your vtec kickin in?"
The reason why i know is not ENGAGING is because i would go and shut off my car and disconnect the vtec solenoid and try it out and it runs as it was before. But i will try bringing a hot wire to the solenoid and try that to see if the solenoid is bad. Thanks for the help everyone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsronhatch »</TD></TR><TR><TD CLASS="quote">i have a 93 civic VX and i did the d15b7 block and a d15z6 head swap. I followed everything that the massive write up said and yet everything works but the VTEC i changed the vtec cilinoid and have the vx wire harness and distributor. What could be the problem???</TD></TR></TABLE>
first, the head is a d'16'z6 (not d15)
second, im not completely sure..but i dont think the VX has a d15b7..isnt it like a b2 or something?? i dunno
third, please tell me u pulled the oil jet between cylinders 2&3...if not, theres ur problem
fourth, **vtec wont engage until the motor has reached operating temperature**
Re: (DaX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DaX »</TD></TR><TR><TD CLASS="quote">Wire up a mad awesome light to your VTEC solenoid and put it on your dash. The light will come on when you're poppin' VTEC in some ricer's face and you'll know it's working! </TD></TR></TABLE>
D@tS 0f D@ 4 Sh33zz33 RiCeR y00!!
Re: VTEC wont pop (HatchEh2)
Yeah, I drove a VX last night. VTEC on single cam's do not engage like a DOHC as far as VTEC goes.
no baaaaaaaaaaaaaa (VTEC) MAHAHAHAHAHAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
for you.
only baaaaaaaaaaaaaaaaa(SOHC VTEC) babaaaaaaaaaaaaaaaaaaaaaa
for you.
How embarassing is this:
When I first got my VX, I thought that I was hearing VTEC engage. It actually turned out to be my ISB in my transmission screaming at high RPMs. Needless to say the ISB exploded a few months down the road and there was no more faux-VTEC sound...only a demolished transmission.
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">did you re-wire the 02 from 5wire to 4wire for the p28? also, do you have an CELs?</TD></TR></TABLE>
Is this question for me? I did rewire and don't have any issues. I did a writeup on the knowledge base on how to rewire.
My mitake i misplaced a number its D16z6 and the shell of the car its a VX the engine came from a Del Sol. And the engine that the car came in it was a D15Z1 Vtec-e. And yes i did take out the oil yet between cylinders 2&3. And i recently just checked my celenoid and it clicked when i put a hot wire to it. Please if anyone else has anymore recomandations please let me know.
