vtec wiring question?
i put vtec wires into ecu they just keep falling out, is their anything i can buy or i can fabricate "specialize" to make them from not falling out? thanks
oh ya, its a 1995 EX motor in a 93 hatch DX
Re: vtec wiring question? (Eibach95Civic)
The easiest way to do it would probably be to go to a u pull-it junkyard with some cargo pants on and and a pair of wire cutters and cut the harness end off of any 92-95 honda. Then pull however many ends you need out and solder them up to your vtec wires and snap them into your connector.
Re: vtec wiring question? (aw1234dude)
yea, or you can just search around and buy two pins (one big, one small) from somebody on here? do a search in classifieds for OBD-1 ecu pins.... you need one of each size, then ground out the negative for the oil pressure switch to something close by in the engine bay.. like the thermostat...
Re: vtec wiring question? (SOHC Beast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC Beast »</TD></TR><TR><TD CLASS="quote">yea, or you can just search around and buy two pins (one big, one small) from somebody on here? do a search in classifieds for OBD-1 ecu pins.... you need one of each size, then ground out the negative for the oil pressure switch to something close by in the engine bay.. like the thermostat...</TD></TR></TABLE>hell yah man i will, and stealling i hate theives
is there any way to bypass the vtec solenoid wiring in the ecu like the oil pressure switch? (search
JinDIESEL
09-28-2004 05:46 AM
