VTEC WIRING
VTEC WIRING
alrighty guys(i have searched) my buddy just put a z6 in his cx hatch and we need to knw what all wires need to be ran for vtec and where to, please
please help guys, i kinda need some pics so i can show him.
thanks guys
thanks guys
* B A N N E D *
Re: VTEC WIRING (yellowjdmcrx)
run wires for vtec, vtec coolant temp, and vtec oil pressure.
no pics sorry, and run them to the ECU where the pins need to be. see jdmlyfestyle's post for ECU pinouts at the top of civic
the 2 wires you run to the ecu are A4 pin and D6 pin. one is the vtec wire and the other is positive from oil pressure sensor. its been so long since I did mine i forget which is which... the only other wire is run the negative of the oil pressure sensor to the chassis for a ground.
k, make it easy and use an ex or si harnass.. then modify the cannon plugs to the ecu...
assuming ur gonna use the p28 ur gonna also need a 4wire o2sensor ...vtec solenoid goes to A4. oil pressure goes to d6 ,ground goes to... well ground..damn i wish i had my notes handy
If you have any questions, just do a bit of searching.
I know its been covered a bunch of times. Lots of pictures available too.
Try searching "wiring vtec" in recent and archived posts.
DJ_SaNdOz
21
01-19-2005 07:49 AM
boosh
07-16-2003 02:30 AM
civicracer1993
15
03-26-2003 05:23 PM
