Vtec with the push of a button
I just droped in my SOHC Vtec and wired the vtec so all i have to do is push a button and its on. Im gonna prob run it this week so how it does. but i def feel a big difference. I hit the button 4g's in 1st and just leave the vtec on from there. ill let you know how it works out at the track.
Re: Vtec with the push of a button (Dont Say Homo)
its always been workin out fine for me... it has the same concept of a vtec controller, plus if its on at 4gs+ its fine?
Re: Vtec with the push of a button (DjFreeze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjFreeze »</TD></TR><TR><TD CLASS="quote">I just droped in my SOHC Vtec and wired the vtec so all i have to do is push a button and its on. Im gonna prob run it this week so how it does. but i def feel a big difference. I hit the button 4g's in 1st and just leave the vtec on from there. ill let you know how it works out at the track.</TD></TR></TABLE>
ok ricer
ok ricer
Re: Vtec with the push of a button (nextelbuddy)
Also if you drain all the oil from your engine you'll gain major Hp because of less mass on the reciprocating assembly.
Re: (1 point 6)
Hey I have felt the power of the SOHC VTEC.....oh wait.....no I haven't
trust me, you will not feel it kick in.
and on top of that, you prolly made it slower.
Re: (1 point 6)
I could be wrong, but...
It was to my belief that VTEC was created in order to give us the best of both worlds; fuel effeciency as well as the characteristics of a high performance motor.
Unengaged vtec = excellent fuel effeciency, while maintaining that minimal econo-horsepower throughout the powerband.
Engaged vtec = poor fuel economy at a higher rpm, giving the motor the capability of producing more power. Why didnt they just make the motors with vtec throught the powerband? This goes back to the musclecar era; experimentation with new cams, valves, blah blah, longer duration. They IDLED LIKE ****, not to mention SHITTY GAS MILEAGE...same with todays cars, however when you have an amazing creation such as vtec, like I said earlier, you get the best of both worlds.
If this kids wants to engage vtec at 4g's through the rest of his gears, let him...I dont see any harm. But I would like to see his track numbers before I make any conclusions
Can someone technically explain how this would/could be harmful?
Changing the VTEC changeover point with a stock cam will only hurt you. The changeover point is designed so just when the power starts dropping on the mild lobes, the more extreme ones switch over. The transition should be seamless.
There is a reason vtec doesn't engage untill the engine is warm, oil pressure is correct, etc. etc. It may seem to work out fine for you now but the gains will be minimal and you are just hurting your motor in the long run. If it really made a big gain don't you think everyone would wire up a switch and/or just always leave it engaged. Even the guys with controllers who drag a lot don't adjust the engagement point very much from stock.
Re: (SleepyDX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleepyDX »</TD></TR><TR><TD CLASS="quote">I could be wrong, but...
Can someone technically explain how this would/could be harmful?</TD></TR></TABLE>
technically.
the ECU has specific fuel maps and equations for specific things that happen. so by him turning it on early or LATE it dosent match the amount of fuel going into the engine. now because its a SOHC its probably not gonna hurt the motor. but it IS slower.
honda engineers spent alot of time figuring out where vtec should engage on each specific motor.
this is not an intelligent way to run vtec, do it right or dont do it at all.
technically.
Don't judge or question
Re: (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin »</TD></TR><TR><TD CLASS="quote">
technically.
this is not an intelligent way to run vtec, do it right or dont do it at all.</TD></TR></TABLE>
You beat me to it! If he engages the vtec with a push button its probably going to run lean and eventually do damage to the engine, and not to mention not add any horsepower at all. I personally think he should do it, one less ricer on the road.
technically.
Re: Vtec with the push of a button (menkio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio »</TD></TR><TR><TD CLASS="quote">lol.. don't be ignorant.. insulting people won't help him much.
And to the ricer, lol sorry.. don't do that.. duh.. your engine
has a vtec point for a reason.. </TD></TR></TABLE>
Yep!
Yep!
Re: Vtec with the push of a button (acuracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing »</TD></TR><TR><TD CLASS="quote">Don't expect to market a product like this...</TD></TR></TABLE>Why not? Ricers love stupid ideas like this. I think its a very marketable idea. hehehe
Former Moderator
Get the right ECU and wire it up correctly.
VTEC "at the push of a button" is ghetto and will not function nearly as good as a good old P28 ECU with it wired up correctly.
As far as changing the VTEC changeover goes with stock cam or cams, it can be done in a manner to increase midrange horsepower and torque but requires the proper air/fuel mixture to accomany it.
Case in point is my own B18C5 engine that saw a huge increase (+20whp and +20ft-lbs. of torque) in midrange just from fuel and VTEC crossover tuning with a V-AFC on a DYNO with wideband o2 sensor - on STOCK cams.
But on a SOHC VTEC engine the increases in power would be very minimal on the stock cam, and few people drop the money to have it tuned the right way in the first place.
Case in point is Mr. Pushbutton VTEC.
Re-chipped ECUs with well-mapped out fuel, timing, and VTEC crossover points can improve upon Honda's ECU designs because Honda has to make a relaible, safe, and fuel efficient program as well as one that makes good power.
1 Post
Re: Vtec with the push of a button (ATgrills.com)
why have a switch?
just hook up the power source from your running lights to the vtec sensor, so when you're driving, just flip your headlights on and you'll have vtec y0!
its already been stated, but you wont feel jack, and it wont make any difference on a track.
