Vtec problems
Vtec problems
Just put in a jdm b16a obd2a. Motor and ecu are stock just have a straight pipe. Something seems off with the vtec cross over but I’m not sure as this is my first vtec. It almost seems like it starts to engage then doesn’t ? Or am I just stupid and that’s how it is. You can hear it in the video
Re: Vtec problems
JDM ECU's do not have a VTP (pressure switch circuit), so it is likely that you do not have enough oil volume to keep the VTEC system locked up mechanically... assuming your solenoid is working properly. Testing the solenoid by replacing yours with a known good one eliminates that possibility... and if that is not it, you have either an oil pump/pickup restriction or the main bearings are worn and allowing too much oil pressure to bleed off.
Good luck.
Good luck.
Re: Vtec problems
Trash in the screen is an indicator that you have other problems like I have suggested above... metal has to come from somewhere... as long as it isn't simply oil sludge built up on the screen.
malo11
21
12-24-2022 04:57 PM
