Vtec problem?
Ok, so i have a 92 civic cx with a jdm integra Type r swap The mods are 4-1 Megan header, test pipe, full exhaust, 255 fuel pump, whale penis intake, p05 ecu with a chip and a street tune (chrome) When i get on in first and second it is fine, but when I am in 3rd or 4th in vtec a CEL will come on and i can feel vtec dissengage. It might be because I am in vtec longer in those gears and there is a short somewhere, I am not sure.. I know vtec had to be wired manually seeing as it is a p05 ecu (stock cx). Any ideas? Thanks
Re: Vtec problem? (Panda Eg6)
bump
how do you get rid of the CEL? is it always there? if so, check what code it's throwing.
Re: Vtec problem? (Blk00EJ8)
nope only when i do pulls in 3rd or 4th. when i turn the key off it goes away.. and is fine. yea i have been looking for that little thing to put the paper clip in to get the code. but i donno if i have one seeing as it is obd2 to obd1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Panda Eg6 »</TD></TR><TR><TD CLASS="quote">I know vtec had to be wired manually seeing as it is a p05 ecu (stock cx).</TD></TR></TABLE>
I just reread your original post and that one line stands out. Sure VTEC has to be wired manually if you're using the stock CX harness, but hopefully you're not trying to use the p05 to run the ITR..? Should be a p73... |
Where was is manually wired to? In the 92 CX you can just tie it into the engine harness because from the strut tower to the ecu is already done for you.
