VTEC not working
Re: VTEC not working (Type-Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Ek »</TD></TR><TR><TD CLASS="quote">hey my VTEC is not working for my EK Coupe
its a d16y7 I installed the y8 head and the vtec dont kick in... whats wrong???
Oil level is fine, spark is fine... it runs strong and smooth but i cant hear vtec like I did before </TD></TR></TABLE>
double check everything. maybe you forgot to connect a wire.
did you pull out the oil jet in the block? between cylinders 2 and 3?
https://honda-tech.com/zerothread?id=635580
scroll down to very important in bold
D Tranny Guru
Re: (brick top)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brick top »</TD></TR><TR><TD CLASS="quote">did you pull out the oil jet in the block? between cylinders 2 and 3?
D16Y7 doesn't have the oil jet in the block
Re: (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone »</TD></TR><TR><TD CLASS="quote">
D16Y7 doesn't have the oil jet in the block </TD></TR></TABLE>
that did cross my mind... oops
Guest
Posts: n/a
Re: (Mista Bone)
uhhhh... are you 100% sure????
Re: (Type-Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Ek »</TD></TR><TR><TD CLASS="quote">... i cant hear vtec like I did before </TD></TR></TABLE>
why are yall asking about the oil jet?
look how he worded that^^
if it was working before, then its not going to be an oil jet.
im going to go with re checking your wiring
yeah but you can still here it?
if so it is just a smoother (better) transition from small lobe to big lobe
