Vtec Install on a 94 Hatch with a Sir-2 B16
what all do I need to install Vtec on my hatch? I know that I need a Vtec Soli switch, pressure switch, knock sensors, evap ****, yada yada. Could this be easily accomplished by having two manuals one for each motor
Re: Vtec Install on a 94 Hatch with a Sir-2 B16 (Vtec Goblin)
Dude you gotta give details on what you're planning to do. Are you going to put a sohc vtec head on, or are you going to swap the entire motor with a sohc vtec motor or swap the motor out for a dohc vtec motor... be specific.
Re: Vtec Install on a 94 Hatch with a Sir-2 B16 (TheFLY)
ok in the title it says that he wants to put a b16 in his 94 hatch. what u are going to have to wire in is the knock sensor, vtec solenoid, and oil pressure. i think that is the only three u have to add.
Re: Vtec Install on a 94 Hatch with a Sir-2 B16 (SpeedRacerEX-R)
thats it 3 wires the rest just plug into the new ecu? Everything from the old wiring stays right? It just plugs into where it went on the stock d15?
Unless he had a SI hatch... Then I believe you dont have to wire up the vtec solenoid, or the vtec oil pressure switch
94cd5c_me_go
11-09-2012 01:46 PM
