VTEC HELP.....
VTEC HELP.....
Okay here is my problem. I just swapped in a jdm R into my EK. The R had no headers. I had USDM 00' B16 exhaust manifold laying around. I put it on and everytime it changes over, I feel a big lag. I was thinking it might be the headers.
My question is, am I able to use the B16 headers on my R motor? Is my motor choking cause i'm using a smaller exhaust manifold?
Anything helps. TIA...
Re: VTEC HELP..... (KILLER_EK9)
when u mean jdm R is jdm integra type r ?
what kind of cat back muffler are u running ? and is b16a exhaust manifold oem or aftermarket? your motor is choking can be caused by several reasons..inspect all the vacume pipes. have u replaced the spark plugs and check their firing order..are u throwing any CEL?also what kind of ecu are u using ?
Re: VTEC HELP..... (crazyguy)
Its an Integra Type R engine. I am running a stock oem cat (00' SI), 2 1/4 piping with stock DX axel back. OEM B16A2 Exhaust manifold. I am using a chipped P28 w/s200...
Cool Cool Island Breezes. BOY-EE
So it's bogging out when you hit VTEC? Maybe the ECU program is running it too lean or rich. The B16A HEADER shouldn't really restrict flow to the point that it bogs out the motor.
Make sure your timing is correct (distributor). What kind of fuel are you using?
Check your fuel filter, air filter, spark plugs, wires, etc.
Are you throwing any CELs?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KILLER_EK9 »</TD></TR><TR><TD CLASS="quote">Its an Integra Type R engine. I am running a stock oem cat (00' SI), 2 1/4 piping with stock DX axel back. OEM B16A2 Exhaust manifold. I am using a chipped P28 w/s200...</TD></TR></TABLE>
u are running dx rear end muffler? isnt it kind of small? like 1.5" or so?
and the chipped ecu p28 , u have it chipped by a pro or ? i
Re: VTEC HELP..... (B serious)
I got no CEL. I'll check the timing though like you said and my ecu should be just fine. ima do that real quick and get back to you. Thanks..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">
and the chipped ecu p28 , u have it chipped by a pro or ? i</TD></TR></TABLE>
Yes, it was chipped by a pro. Umm, I just swapped out a B16A2 and ran the same setup except for the ecu. I never had this problem with the B16.
Yes, it was chipped by a pro. Umm, I just swapped out a B16A2 and ran the same setup except for the ecu. I never had this problem with the B16.</TD></TR></TABLE>
That's cuz the B16A is superfast.
SimpleAznMan
Honda Civic (2001 - 2005)
01-19-2010 07:20 PM
AllMtorEg
06-26-2007 02:10 AM
