VTec Head!!
Darth ModerVader
Re: VTec Head!! (JDM_COUPE94)
Why would you need pictures?
The best VTEC head would be the one that you can find in the best condition for the least amount of money. None has a significant advantage over the other, with the exception of the ITR.
Re: VTec Head!! (Padawan)
gsr has a closed deck resulting in higher compression numbers which=stronger, b16 and itr=same except itr is slightlly ported.
end thread
end thread
Darth ModerVader
Re: VTec Head!! (SPITVENOM67)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPITVENOM67 »</TD></TR><TR><TD CLASS="quote"> gsr has a closed deck</TD></TR></TABLE>
No, it doesn't.
However, the P72 head will yield higher compression due to a smaller combustion chamber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPITVENOM67 »</TD></TR><TR><TD CLASS="quote">b16 and itr=same except itr is slightlly ported.</TD></TR></TABLE>
The castings are the same, but aside from the mild work it receives from the factory, there are also differences in the valvetrain (cams,valves, springs, LMA's).
No, it doesn't.
