VTEC in D16Z6
1 Post
VTEC in D16Z6
hello everyone, i drive a 92 civic si with a D16Z6 that has 261,000 miles on it. i was wondering what RPM the vtec kicks in on this motor...it sounds like it is around 5.2k or so??? any help will be appreciated
Re: VTEC in D16Z6 (DJ_SaNdOz)
5200. Just to let you know you are going to get like 50,000 different answers on this. Welcome to HT. JUst a Heads up......Use the search function
Re: VTEC in D16Z6 (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">5200. Just to let you know you are going to get like 50,000 different answers on this. Welcome to HT. JUst a Heads up......Use the search function</TD></TR></TABLE>
There are several VTEC points, low engage, high engage, as well as high disengage and low disengage depending on the conditions. 5200ish is probably correct for the high engage point.
Re: VTEC in D16Z6 (toonRsi)
on the way to trouble shooting v-tech
honda manual in the engine section of diagnose
a.) test drive
bring vehicle to operation temperature about 98 (degrees F)
in first gear accellerate to 5,300 rpms hold for about 5 seconds
if M.I.L. appears then check V-TEC components
( End quote )
this suggests that V-TEC engauges at max 5,300 rpms when idely it shoud in faq
happen at 4,800 rpms
a.) test drive
( End quote )
Re: VTEC in D16Z6 (sloz64now)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloz64now »</TD></TR><TR><TD CLASS="quote">your hittin vtec in a sohc with 261k miles?!? cant wait to see it go boom</TD></TR></TABLE>
or not, thats what the car is designed to do.
Re: VTEC in D16Z6 (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote">or not, thats what the car is designed to do. </TD></TR></TABLE>
with that many miles?
its a hydraulic system, what can fail if it has good oil and everything is ok. Hitting vtec won't cause premature engine wear anywhere that wouldn't have been caused revving to 4600 rpm. Redlining is a different story, and i wouldn't suggest that on a regular basis, but thats another story.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch »</TD></TR><TR><TD CLASS="quote"> Redlining is a different story, and i wouldn't suggest that on a regular basis, but thats another story. </TD></TR></TABLE>
well usually the only time i hit vtec is when i redline, so thats y i said that
you're an idiot
you're an idiot
Re: VTEC in D16Z6 (Daniel_san)
WTF?
WTF?
idiot
I'm at 247XXX KM's and motor and Vtec run properly
idiot
well usually the only time i hit vtec is when i redline, so thats y i said that</TD></TR></TABLE>
get the **** off my internet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daniel_san »</TD></TR><TR><TD CLASS="quote">
get the **** off my internet</TD></TR></TABLE>
lol
lol
Electrician
What the hell does the mileage have ANYTHING to do with the engine going boom?
stupid.
opps i didnt read the whole post when i posted, everyone flamed him already
me
stupid.
me
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sloz64now »</TD></TR><TR><TD CLASS="quote">with that many miles?</TD></TR></TABLE>
Mine's got 250,000+ and I road race it. If holding it between 4000-6500 rpm for hours isn't killing it, tapping VTEC once in a while won't either.
Re: VTEC in D16Z6 (Archidictus)
i have a question related to this. do different ecus, but the same family(p28), cause different vtec engagement points?
with my stock p28, i hit vtec around 4900rpm. it is unmodified
with a friend's stock p28, i hit it around 5200rpm. is this difference normal?
Re: VTEC in D16Z6 (TekSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TekSI »</TD></TR><TR><TD CLASS="quote">i have a question related to this. do different ecus, but the same family(p28), cause different vtec engagement points?
with a friend's stock p28, i hit it around 5200rpm. is this difference normal?</TD></TR></TABLE>
interesting...i'd like to know too!
also im at 215k in my Eg Si and still pulling hard!
