VTEC on B16A1 with VSS from B16A2
Hi guys,
quick but important question....
I have A B16A1 engine. Normally the speedo runs with a cable to the dash and from the dash a wire runs to the comp for the use of VTEC.
I build the engine in the back of a classic mini but I cant run the speedo cable to the dash due to length.
What I did is I took the VSS from an A2 engine. That one is electric. I ran that wire to the computer.
Will this work??
Thanks
René
Will this work??
Thanks
René
Re: VTEC on B16A1 with VSS from B16A2
Oke. Back at it.
Still got a code 17... So.... The VSS still doesn't work.
I bought a new VSS sensor and still nothing.
I read some were that the wires on the VSS connector can be different. I connected it as 12V, signal, ground. But It could be signal, 12V, ground. Is this something I can 'just' try out?
So I'm confused.
Any leads on where to go next? Just try to swap the wires?
Thanks
So I'm confused.
Thanks
Oke, that was it. I still can't figure out why I did what I did. probably because I went from mechanical to electrical speedsesor.
So the right way is signal, 12v, ground
Anyway. I have VTEC YOOOOOOO. Hahahaha.
thanks for all the help....
René
René
turbo_b16_ex
06-04-2008 11:56 AM
GI8U2racing
10
10-10-2007 05:28 PM
Dohc 4door Rye
05-23-2006 08:14 PM
fastcat1
12-31-2002 01:13 PM
