Vss Sensor *How to tell if its bad?*
Heres my situation i was changing a coolant hose and i guess i got some coolant into the vss sensor my speedo keeps going up and down no matter how fast im going. But its not coding how do i clean this and does this sound like what my problem is???
Re: Vss Sensor *How to tell if its bad?* (Spence)
take it out spray some brake cleaner on it dry it up nice and good. and see what happens
Re: Vss Sensor *How to tell if its bad?* (hayabusa160)
[QUOTE=Spence]my speedo keeps going up and down no matter how fast im going. QUOTE]
There is your answer right there. |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hayabusa160 »</TD></TR><TR><TD CLASS="quote">take it out spray some brake cleaner on it dry it up nice and good. and see what happens </TD></TR></TABLE>
brake cleaner will eat shit up |
Re: Vss Sensor *How to tell if its bad?* (Art In Motion)
There are screws on the cluster board inside the cluster.. tighten all the screws because if there loose that could be your problem.
Do this only if it still does it have you replace the VSS |
Re: Vss Sensor *How to tell if its bad?* (TwoPointZero)
Well so then what should i clean the vss with???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence »</TD></TR><TR><TD CLASS="quote">Well so then what should i clean the vss with???</TD></TR></TABLE>
Just use a damp cloth if anything. If your speedometer is jumping...most likely your VSS went bad. Cleaning it wont fix it |
Re: Vss Sensor *How to tell if its bad?* (Mr.RHTuner)
The thing is that i had no problems until i changed the coolant hose and i had some coolant come out of the firewall locatation when i pulled the hose off.
if you need a vss just let me kno i got one laying around
D series
up so why is it not coding if its bad???
Its not throwing any codes?
Re: Vss Sensor *How to tell if its bad?* (Built2Spill)
nope no codes
how old/new is your car?
when my vss was all messed up it didnt throw any codes.
but it was because the pin on my harness was broke so it didnt get full contact. the speed would jump all over |
But from what we know he didn't mess with his vss ...so a broken pin wouldn't matter. The only possible explaination i can think of is you could have shorted out the vss/sensor from spilling the coolant..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Built2Spill »</TD></TR><TR><TD CLASS="quote">how old/new is your car?</TD></TR></TABLE>
its a 98 motor in a 95 hatch |
go to radio shack or somewhere and get some contact cleaner,..clean up the harness really well,..let it dry out,..and then plug her back in,..i got my VSS wet awhile back while degreasing underneath the hood,..the speedo would die out and kick back on the day after i washed things under the hood,..after a couple days it dried out and the speedo went back to normal
hayabusa160: is that VSS for a Dseries motor or bseries motor? |
Re: Vss Sensor *How to tell if its bad?* (2.0 EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.0 EK »</TD></TR><TR><TD CLASS="quote">hayabusa160: is that VSS for a Dseries motor or bseries motor? </TD></TR></TABLE>
it doesn't matter, they're interchangeable https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: Vss Sensor *How to tell if its bad?* (AzntaggeR)
yep they are interchangeable i used my d15 vss on my b series tranny worked fine i think the d series one is better its all metal unlike the bseris one thats all plastic.
not to hijack the thread, but what would cause the speedo to read way off. i have a gps unit and it sayes when my speedo reads 120, im actualy doing 113. and at 75, im actuly going 70, is this the vss. this is on the 13" oem wheels so incorrect tire size isnt the problem.
Re: Vss Sensor *How to tell if its bad?* (a1320honda)
all speedos are off from the factory. There are actually SAE guidelines as to how much they can be off at certain speeds. American cars are closer to correct than Japanese cars...and German cars are the most off.
hey Spence did you fix ure problem mine doin the same thing
They sell a spray-can of contact cleaner at the autoparts store too. It's great stuff. Spray it down good, let it dry, then put a thin coat of diaelectric grease back on the contacts before reassembly.
The test procedure for it's a bit lengthy, and not something I'm going to type out for fear of you zapping something. Clean it up, if it doesn't work, go steal one from a buddy and see if that fixes it. |
prolly not just a little dampstill
when it breaks it doesnt throw any codes my hatch's tach worked sometimes but no speedo when it broke untill i remembered i had a GSR tranny laying around and jacked the one off that. |
