VIS CF OEM Hood + 96 Civic Hatch + B16 Swap
So from what I've been reading about in one of the other guys posts about a VIS hood not fitting... I have a 96 Civic hatch, and plan to do a B16 swap. Would doing a 99-00 front end conversion be enough for a VIS OEM Style CF Hood be enough for that to fit? Is the radiator support higher or something? Or would just swapping out the headlights, fenders, and bumper cover be enough?
Really I'm just trying to plan ahead here... any thoughts or comments would be great thanks!
Re: VIS CF OEM Hood + 96 Civic Hatch + B16 Swap (CNY Hatch)
Are you talking about the new generation VIS?
If you are they hit the valve cover on swapped civics
Re: VIS CF OEM Hood + 96 Civic Hatch + B16 Swap (rolow)
i have the new generation vis hood on my 97 hatch and it fits fine with my b18. no issues with hitting the valve cover
i dont believe fiber images have this problem...
but even if it does slightly contact the cover, just do some trimming on the skeleton and youre good to go
Location: Toronto, Canada currently residing in ATL, GA, USA
Re: (pdiggitydogg)
On 5th gen civics its very bad. ON 6th hatch's it isn't as bad because 99-00 civics came with B series motors
B18C-Hatch-Turbo
12-21-2004 12:00 PM
