Verify GSR front/rear brakes
Old 07-09-2008, 07:42 PM
93preludeh22's Avatar
Default Verify GSR front/rear brakes
How can you determine if brakes are from a 94-01 GSR integra? Going to be picking up front and rear setup from someone.
Thanks
Anthony
Old 07-09-2008, 07:48 PM
BlueIntegraBoy's Avatar
Default Re: Verify GSR front/rear brakes (93preludeh22)
All 94-01 non ITR brakes are the same. All 90-01 Integra (non-R) and 88-00 Civic rear disks are all the same, except 90-93 Integra trailing arm bushings are larger (but won't affect installation). Measure the front rotors. Diameter should be 10.25". Look on the knuckle and look for the holes for the ABS sensor brackets. To distinguish 90-03 Integra and 94-01 Integra knuckles, look at the top of the knuckle where it bolts to the UCA, if you see two screw holes at the top then they're 90-03 Integra (and won't fit right on your ride).
Old 07-10-2008, 07:48 AM
The fronts and rears all have the ABS sensors still attached. I'll measure tonight. What is the diameter of the rear?
1EK1EG
08-05-2015 09:25 AM
Alucard-1524
11-01-2011 04:58 PM
crazy irishman
10-14-2009 11:32 PM
Quick Reply: Verify GSR front/rear brakes
