Valves tapping sound
Old 11-19-2003, 08:26 AM
Old Member
GoLowDrew's Avatar
Default Valves tapping sound
Sometimes I hear it when the car is going on a slight hill. I'm in the right gear. Example (70mph in 5th). Why does it not have the tapping sound going downhill?
Educate me, what is the cause?
TIA
Old 11-19-2003, 08:46 AM
Spade's Avatar
Default Re: Valves tapping sound (GoLowDrew)
lack of load?
Old 11-19-2003, 03:08 PM
New User
spyder's Avatar
Default Re: Valves tapping sound (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade &raquo;</TD></TR><TR><TD CLASS="quote">lack of load?</TD></TR></TABLE>
yeah, that's why
Old 11-19-2003, 03:09 PM
mad_96civic's Avatar
lack of oil, your oil runs to the back of your enjine and cant get sucked up easily.
thus noisy valves
Old 11-19-2003, 03:10 PM
New User
spyder's Avatar
Default Re: (mad_96civic)
not too sure about that mad_96civic...
back when my car was actually running, if i accelerated hard downhill, i could still hear tapping
Old 11-19-2003, 03:20 PM
HATCHingMN's Avatar
Default Re: (spyder)
Could a leaky headgasket cause valve tapping too?? I think I may have that on my lil sohc z6!!
Old 11-19-2003, 03:30 PM
well when your enjine has "little" oil in it itll take some time to get back in it wont kick in right away
or it could be a loose part that when angled rubs against ______
Old 11-19-2003, 03:31 PM
New User
spyder's Avatar
btw...out of curiosity... what's a '96 civic si?
Old 11-19-2003, 07:22 PM
haby red fg2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spyder &raquo;</TD></TR><TR><TD CLASS="quote">btw...out of curiosity... what's a '96 civic si?</TD></TR></TABLE> he would probably be from canada there ex is called a si
Old 11-19-2003, 07:56 PM
SOHC_MShue's Avatar
try doing a valve lashing
Old 11-19-2003, 08:00 PM
Lysawy's Avatar
Default Re: Valves tapping sound (SOHC_MShue)
looks like your engine i knocking , could be bad gas, your timing is off, check these if your valves are off you would be able to hear the at idle
Old 11-19-2003, 08:11 PM
nonsense's Avatar
Default Re: Valves tapping sound (Lysawy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lysawy &raquo;</TD></TR><TR><TD CLASS="quote">looks like your engine i knocking , could be bad gas, your timing is off, check these if your valves are off you would be able to hear the at idle
yeah, that's what I was thinking too. I doubt that valves would be noisy only when under a load and not at other times too. I'd check the timing too. When was your last tune-up? Have you ever replaced the fuel filter?
Steve
Old 11-19-2003, 10:18 PM
Tofurky's Avatar
that's probably the culprit...
rondogg779
10-28-2019 11:19 PM
theineffable
Honda Civic (2001 - 2005)
08-09-2010 11:01 AM
liem43
06-30-2010 08:41 AM
vbcrixmanz
05-17-2008 10:23 AM
Quick Reply: Valves tapping sound
