valve ticking
as the topic says I searched. i noticed not to long after i put my dc sports 421 header on i noticed a loud ticking. i changed the block to header gasket. nothing then i changed the donut gasket nothing. i then thought it was the injectors so i put some cleaner in a full tank but still nothing. im bout sure it is the valves. my ? here is. is it hard to adjust valves? if not then will i have to do it every week. my bro's valves ticked on his accord and he had to adjust like once a week. so if im gonna adjust them should i just get like some skunk2 stock size valves or something? and should i change everything else that goes with the valves or no?
this is on a 94 civic ex d16z6 sohc vtec thanks a bunch |
Re: valve ticking (sohctodohc)
i just searched "valve ticking" and found 20 results
https://honda-tech.com/zerothread?id=906249 https://honda-tech.com/zerothread?id=544224 these 2 were from this forum and most of the other ones were in the tech forum but i didnt feel like posting them all https://honda-tech.com/forums/images...es/emdgust.gif https://honda-tech.com/zerothread?id=799825 here is another link i found in the tech forum...a guy with a 95 civic asking how to adjust valves... Modified by CivicEX96 at 1:12 PM 9/21/2004 |
he had to adjust his valves once a week!? i think he is doing it incorrectly or just being stupid. You adjust your valve lash because over time the stock cam wearsdown and the lift/duration is changed so by doing the vlave lash it allows you to regain the lost lift/duration. U sure its not the injectors cause putting the cleaner in there wont make it stop maybe quiet it slightly but nothing obvious.
Re: valve ticking (Soccerking3000)
what i searched for is if i should change or buy new valves. that was my question and it wasn't ever answered. so like i said i searched. https://honda-tech.com/forums/images...es/emsmile.gif
u dont have to get new valves and if u adjust them right it will go away it isnt easy it takes a while to get them done and yes adjust them
Re: valve ticking (HondaIntegraGSR)
on my motor d16z6 wut is the size of the nut??? would nebody no
You could try changing the oil and adding one qt of transmittion fluid unstead of your last qt of oil. It leans the oil out, sometimes trash gets in the holes where oil is supposed to lube the cam. It's work for me before and you'll know if its the valve.
the nut on the rocker assembly? it is a 10mm. also the chiltons manual specifies that you should adjust your valves every 15K miles, and it has a detailed write-up on how to do it. have somebody around that is mechanically inclined when you do this if you dont feel comfortable doing it alone. i would start by adjusting your valves since it sounds like yours hasnt been done in a long time and it is free and you can narrow it down from there. you also dont have to buy new valvetrain components to do this. all you have to do is remove the valve cover. you will need a flat screwdriver, a 10mm wrench/socket, a feeler gauge and 17mm socket to turn the motor over. you will also need a torque wrench to make sure all the nuts are torqued to spec when you are finished. https://honda-tech.com/forums/images/smilies/emthup.gif
Re: valve ticking (lohatch)
what places carry the chiltons manuals? and ni have the haynes but i dont think it explains valve adjusting. how do u no how much to tighten the 10mm bolts down
haynes has valves in it..thats where i learned how to do mine..wasnt to hard at all..ptu the feeling gauge in and when it feels like it kinda hard to get it out, but can still slide arounda little..tighten it up..i had no more tap
Re: valve ticking (LSracing94)
o i read through my haynes and it mainly said to bring it to a a mechanic cause it is to hard to do at home haha. neways alright i think me and my bro are gonna break into to it tom. neways to start off with do u have to have it at tdc? thanks for all of the help
the 3rd link in the second post tells you step by step,
correction, the third link gives you the link to cspeed diy for dohc |
Re: valve ticking (spicoli)
https://honda-tech.com/zerothread?id=561916
diy d series valve adjust with pics yo https://honda-tech.com/forums/images/smilies/emthup.gif |
